Firmware for MD96800
  • Hello,
    I have Medion MD 96800 MDPNA 250 T and have a problem.
    After power on on my screen visible only text installation files not found in sd/mmc card. Could help me anyone in this situation?
    I want upload firmware again to pna but i can't find it in internet (any rom)
    under case have Win CE .NET 4.2 Core and numer for licence.
    Could anyone may help me and give link or something for firmware for this device?
    Thanks a lot.
    Mark
    PS. I don't understand german, than i prefere to speak in english.
    welcome here.
    In my opinion you are using the Medion-Software on your PNA. Could you verify the version, maybe take a look at the CD/DVD you got with the MD 96800 and post it here.
    Would you please then take a look at the SD-card using a cardreader. Using Medion 5.X, you must find there an various map and two files called "mnavdce.cab" and "autorunce.exe".
    After storing the card into the PNA and doing a hardreset, the installation mostly started properly.
    The WinCE stays in the ROM and isn't needed to restore. Maybe only the battery was empty and you have to restore the program like above written.
    Greets
    Harald
  • Hmm, i does hard reset but device still ask me for this files. I don't know what's happend. And i have problem with original cd's, because i haven't it. I have only pna, cable for usb to pc, and recharge.
    Deleted from the administrator!! Reason? Just look on what HSVMichi wrote
    Greets JEWUWA
    Einmal editiert, zuletzt von marko-wroclaw ()
    Original von marko-wroclaw
    And i have problem with original cd's, because i haven't it. ...
    No original cds, no support.
    please do not ask for files if you have no original software.
  • Whatt!! Always think that most important for legal and etc. is certificate (and this i have), but not cd's... I think that here someone have no idea to know what is legal... I have, paper when i bought pna- certificate with number... but have not only cd. Cd is only cd...
    I'm sorry for taking your time... Maybe someone another will be more helpfull and competent.
    btw. I working in computer shop and i know what is legal and proper system.
    what are you expecting? If you bought a bundle of an Medion-PNA, the CD's are included. If you lost (or whatever) your CD's, you may ask the Medion-Support for compensation by showing your papers.
    One of the competent users in this forum had given you an clear answer about our rules. And so is my opinion, too.
    Greets
    Harald
  • OK - no problem....
    I''ve solution. Thank you for help.
    Greetings.
    Mark
