Problem gelöst : TTM und andere "GPS Mäuse"
  • @bullterrier:
    was ist xtrack gibt es dafür einen set-befehl?
    das ist die t-mobile maus mit gelöteter brücke,
    umprogrammiert in gga- modus boudrate 4800 (änderbar)
    mit gps utlility geloggt.:
    <-$GPGGA,201329.346,5447.8357,N,00927.3348,E,1,04,4.5,75.6,M,,,,0000*3F
    <-$GPGSV,3,1,11,15,77,086,40,03,77,253,41,21,54,116,,22,50,136,47*71
    <-$GPGSV,3,2,11,18,49,080,36,31,37,291,,02,36,297,,17,31,064,*70
    <-$GPGSV,3,3,11,26,16,072,,27,11,292,,08,06,348,*42
    <-$GPGGA,201330.346,5447.8357,N,00927.3349,E,1,04,4.5,74.5,M,,,,0000*34
    <-$GPGGA,201331.346,5447.8358,N,00927.3352,E,1,04,4.5,73.5,M,,,,0000*37
    <-$GPGGA,201332.346,5447.8357,N,00927.3352,E,1,04,4.5,72.7,M,,,,0000*38
    <-$GPGGA,201333.346,5447.8355,N,00927.3354,E,1,04,4.5,73.0,M,,,,0000*3B
    <-$GPGGA,201334.345,5447.8352,N,00927.3356,E,1,04,4.5,73.4,M,,,,0000*3E
    <-$GPGSV,3,1,11,15,77,086,41,03,77,253,42,21,54,116,,22,50,136,47*73
    <-$GPGSV,3,2,11,18,49,080,38,31,37,291,,02,36,297,,17,31,064,*7E
    <-$GPGGA,201335.345,5447.8350,N,00927.3359,E,1,04,4.5,74.4,M,,,,0000*35
    <-$GPGGA,201336.345,5447.8346,N,00927.3363,E,1,04,4.5,76.0,M,,,,0000*3E
    <-$GPGGA,201337.345,5447.8342,N,00927.3367,E,1,04,4.5,78.0,M,,,,0000*31
    <-$GPGGA,201338.345,5447.8338,N,00927.3370,E,1,04,4.5,80.1,M,,,,0000*33
    <-$GPGGA,201339.345,5447.8335,N,00927.3372,E,1,04,4.5,81.7,M,,,,0000*3A
    <-$GPGSV,3,2,11,18,49,080,37,31,37,291,,02,36,297,,17,31,064,*71
    <-$GPGGA,201340.345,5447.8332,N,00927.3374,E,1,04,4.5,83.0,M,,,,0000*30
    <-$GPGGA,201341.345,5447.8329,N,00927.3376,E,1,04,4.5,85.1,M,,,,0000*3E
    <-$GPGGA,201342.345,5447.8326,N,00927.3378,E,1,04,4.5,86.6,M,,,,0000*38
    Finished with Comms.
    Einmal editiert, zuletzt von stromi ()
  • Hannus max kann dir keinen tip geben. der hat null ahnung und profilneurose
    ausserdem bekommen hollaender doch alles bei marktplaats billiger. wieso eigentlich immer leute um ihre arbeit prellen und nicht bezahlen wollen?
    wuerde mir mal echtes software paket kaufen
  • @hampelmax ?????????????
    @jeder
    Ich habe jetzt schon vieles probiert aber kein succes. Ich habe ein fortuna clip-on mit normale modus und xtrack 2 modus. Diese wil nicht arbeiten mit ttm. Hat jemand von ihnen das schon hin bekommen?
    grusse
    Ruben
  • ich habe eine royaltek gps und bekomme es einfach nicht hin das diese von TTM erkannt wird. was kann ich da machen? hat einer schon ne lösung?
  • hallo
    also das soll alles funktionieren
    R66 mobile:
    SX1 - Fortuna Clip-ON -> OK
    SX1 - Falcom Navi 1 -> OK
    SX1 - Royaltek RBT 1000 -> nicht 100% (Da gibts Probleme in der Kombination mit dem SX1, deswgen hat der Hersteller die Mäuse getauscht)
    SX1 - Royaltek RBT 3000 ->OK
    Nokia 6260 - Royaltek RBT 1000 (ohne XT) -> OK
    Nokia 6600 - Falcom Navi 1 -> OK
    Nokia 7610 - Fortuna ClipOn -> OK
    Nokia 7610 - Royaltek RBT 1000 (ohne XT) -> OK
    TT mobile:
    Nokia 6600 - Royaltek RBT-1000 mit XTRAC 2 -> OK
    Nokia 7610 - Fortuna Clip On -> ??
    beliebiges Handy - Falcom Navi 1 -> Maus macht Probleme
    SX1 - beliebige Maus -> Handy macht Probleme (Überhaupt kein Start möglich
    gruss frank
  • TT mobile:
    Also genau das habe ich gerade ausprobiert und nicht zum Laufen bekommen. Mach ich irgendwas mit dieser Dateilöscherei falsch oder funktioniert der Trick generell nicht? Gibts irgendetwas anderes, was ich tun kann?
    Einmal editiert, zuletzt von Quark ()
  • @all
    Es reicht nicht, einfach die dateien zu löschen, man braucht auch eine ANDERE
    "ttmobile.app"
    Sonst wird das nix.....
    Nur von mir nochmals der Hinweis :
    Legal is das nich......
  • Royaltek RBT 3000 mit TomTomMobile -> ok (mit gepatchter ".app" Ist nicht leg.....) ;)
    Ich habe mir mal die "GPS-Maus" Mitschnitte von der TomTom und von der RoyalTek angeschaut.
    Bei der TomTom kommen die NMEA-Daten sehr chaotisch :
    --- cut ---
    $GPGGA,141636.830,4812.9439,N,01119.1196,E,1,05,3.7,545.5,M,,,,0000*0C
    $GPRMC,141636.830,A,4812.9439,N,01119.1196,E,0.00,,241004,,,A*70
    $GPVTG,,T,,M,0.00,N,0.0,K,A*13
    $GPGGA,141637.830,4812.9439,N,01119.1190,E,1,05,3.7,555.6,M,,,,0000*09
    $GPRMC,141637.830,A,4812.9439,N,01119.1190,E,0.00,,241004,,,A*77
    $GPGGA,141638.830,4812.9439,N,01119.1190,E,1,05,3.7,555.6,M,,,,0000*06
    $GPRMC,141638.830,A,4812.9439,N,01119.1190,E,0.00,,241004,,,A*78
    $GPGGA,141639.830,4812.9439,N,01119.1190,E,1,05,3.7,555.6,M,,,,0000*07
    $GPGSA,A,3,05,24,04,01,25,,,,,,,,5.2,3.7,3.7*34
    $GPGSV,3,1,10,30,73,301,,05,67,078,33,06,38,218,,24,33,083,44*7F
    $GPGSV,3,2,10,14,32,258,,17,27,120,22,09,27,148,,04,19,045,38*75
    $GPGSV,3,3,10,01,17,320,32,25,14,313,24*7A
    $GPRMC,141639.830,A,4812.9439,N,01119.1190,E,0.00,,241004,,,A*79
    --- cut ----
    Bei der Royaltek :
    --- cut ----
    $GPGSA,A,3,,,,,,,,,,,,,3.0,2.3,,*32
    $GPGGA,091626.868,4812.9552,N,01119.1255,E,1,05,2.3,560.3,M,,M,,*45
    $GPRMC,091626.868,A,4812.9552,N,01119.1255,E,0.299353,0.000000,281004,,*08
    $GPGGA,091627.868,4812.9561,N,01119.1263,E,1,05,2.3,559.4,M,,M,,*4C
    $GPRMC,091627.868,A,4812.9561,N,01119.1263,E,0.250798,0.000000,281004,,*0A
    $GPGGA,091628.868,4812.9568,N,01119.1269,E,1,05,2.3,558.3,M,,M,,*46
    $GPRMC,091628.868,A,4812.9568,N,01119.1269,E,0.177799,0.000000,281004,,*01
    --- cut ----
    Das "Problem" das die "GPVTG" Daten bei der Royaltek fehlen habe ich mitlerweile auch bemerkt. (habe ich schon bei meiner Royaltek eingestellt ;)
    Ich denke in den "TTM-Maus" Daten ist schon eine Struktur
    drin (ich habe die leider nicht erkannt) Ich denke mal daher erkennt er ob es eine TTM Maus ist oder eine eines Fremdherstellers!
    Bastle weiter an einer legalen Lösung !
  • Hat jemand vielleicht auch eine losung fur die spv e200? Die losung fur die nokia 6600 funktioniert nicht auf die e200.
    Ruben
    Original von rwijnhov
    Die "Lösung" kann ja auch gar nicht auf dem Orange SPV e200 funktionieren!
    Das ist kein Symbian OS Handy, sondern ein Handy mit "M$ Smartphone 2003" Betriebssystem.
    Da müßte man dann wohl die ".exe" Datei patchen. Eigentlich auch kein Problem, aber das mit dem testen der Software ist etwas schlecht, da ich kein "SPV E200" habe :(
  • Ich wurde es gerne fur sie testen. Bitte schik mich einen e-mail at wizzard@raketnet.nl. Ich mochte gerne ein aderen gps maus nutzen mit meiner e200.
    Vielen dank,
    RUben
  • mal eine frage, beim orange hast du doch eine .exe und keine .sis, aber die app ist doch bei allen gleich, oder?
    von daher sollte es auch kein problem sein.
    berichtigt mich, wenn ich mich irre!
    gruss
  • hallo
    normalerweise müsste doch tom tom mobile auf beiden systemen laufen ,also auf symbian und mobile 2003 smartphone ,geht ja auch auf den qtek 8080 oder täusche ich mich da
    gruss frank
  • Das würde mich jetzt auch interessieren:
    TT mobile:
