My german is a bit rusty, but i can read it ok, i can buy a medion 40600 (aldi bundle) as this will be my first pda , i would like some advice about how to check this pda when i get there.
it is not complete, it is just the pda and the mouse + mouse cable, no cradle or pc/pda wire, but the asking price is just 125 euro.
is there an easy way to check if the navigation/mouse /voice works ok ?
Thanks in advance,
Linda, Niederlande
Original von linda
Thanks in advance,
Linda, NiederlandeHi Linda,
checking the PDA is no Problem, there is a simulation mode for checking the navi-software. For trying the mouse-function you'l need a kind of power supply for the mouse, f.e. a car Y-cabel for mouse and PDA -
thanks for your reply, the y cable is there, so if i plug this in the car ciggarette lichter and the pda ,i can simulate navigation ?
would this simulation mode be easy to find ?
thanks,Linda -
Original von linda
thanks,LindaIf you have already a navigating programm you need not to simulate; then you simply navigate.
But If you actually have no programm then you cannot simulate. But you can test the mouse by some freeware like GPSMOUSE or VisualGPS.
the medion is sold! schade, thanks for your replies ,
i can use it another time.
cheers, Linda -
Original von linda
cheers, LindaI did'nt understand. What is "schade"?
Of course you can use your navigating programm, and with it you can also simulate.But for simulating you need no GPS.
Original von HSVMichi
Michi, Linda wollte kaufen, kam aber zu spät! ;D
