Ich möchte meine Rikaline 6010 für einen Auslandstrip gerne mit den Koordinaten des Ankunftsflughafens initialisieren um schneller eine vernünftige Ortung zu haben. sirfdemo3.36 bietet zwar eine solche Funktion, verlangt aber das Einlesen eines Positionsfiles *.pos. Weiß jemand was das ist, wie man das erstellt, oder ob es eine andere Möglichkeit zur Initialisierung gibt?
Hi, sollte sie im NMEA mode sein dann must du folgendes machen:
This command is used to initialize the Evaluation Receiver by providing current
position (in latitude, longitude, and altitude coordinates), clock offset, and time.
This enables the receiver to search for the correct satellite signals at the correct
signal parameters. Correct initialization parameters enable the receiver to
acquire signals quickly.
Table 18 contains the input values for the following example:
Start using known position and time.
$PSRF104,37.3875111,-121.97232,0,96000,237759,1946,12,1*07Message ID $PSRF104 PSRF104 protocol header
Lat 37.3875111 degrees Latitude position (Range 90 to -90)
Lon -121.97232 degrees Longitude position (Range 180 to -180)
Alt 0 meters Altitude position
ClkOffset 96000 Hz Clock Offset of the Evaluation Receiver17
TimeOfWeek 237759 seconds GPS Time Of Week
WeekNo 1946 Extended GPS Week Number (1024 added)
ChannelCount 12 Range 1 to 12
ResetCfg 1 See table 19
Checksum *07
<CR> <LF> End of message terminationist sie im SIrf mode:
2.1.2 Initialize Data Source - Message I.D. 128
Table 24 contains the input values for the following example:
Warm start the receiver with the following initialization data: ECEF
XYZ
(-2686727 m, -4304282 m, 3851642 m), Clock Offset (75,000 Hz),
Time of Week (86,400 sec), Week Number (924), and Channels
(12). Raw track data enabled, Debug data enabled.
Example:
A0A20019 Start Sequence and Payload Length
80FFD700F9FFBE5266003AC57A000124F80083D600039C0C33
Payload
0A91B0B3 Message Checksum and End Sequence
table 24 Initialize Data Source
Name Bytes Binary (Hex) Units Description
Scale Example
Message ID 1 80 ASCII 128
ECEF X 4 FFD700F meters
ECEF Y 4 FFBE5266 meters
ECEF Z 4 003AC57A meters
Clock Offset 4 000124F8 Hz
Time of Week 4 *100 0083D600 seconds
Week Number 2 039C
Channels 1 0C Range 1-12
Reset Config. 1 33und dabei die richtige checksum ausrechenen und mit einem Terminal programm senden.
Sollte so etwas gewünscht werden kann ich das in GPSMAUS einbauen.
doch Anregungen und so weiter kommen leider keine.
Hallo blackvara
Was mir gefallen würde, generell, wär für viele toll,
irendwo, einen überübergroßen Laufbalken.
so breit, wie das Display.
Und in unheimlich großen Lettern,
die jeweilige Gewindigkeitsangabe.Das wär sehr schön zum Tacho-, eichen, testen.
Ich hatte mal früher so ein schönes Tool,
von "supervisioncam"
jedoch komme ich da mit meiner TMC Maus nicht ran.vlG bab
Die Km/ h Anzeige so richtig schön groß und fett
bab, das Tool von Peter ist eigentlich zum Umprogrammieren von Mäusen gedacht und nicht für den Betrieb während der Fahrt.
Oder ist mir da was entgangen? -
Hallo Peterpu
Ich seh`das so, hihi
Peter hat seine Gründe warum er nachfragt,..
ich nenn es: er will sich nützlich machen,.. ist ja auch egal
Ich gehöre nicht zu den Leuten, die alle 2 Min. was testen wollen,
denn ich hab`( für mich ) das beste System.
Aber so eine Tachoanzeige, kann doch jeder mal brauchen,
und sei es, um neue , mmmh Mitglieder zu werben.Ich kenn noch viele, die mit der Stoppuhr die Balken auf der Autobahn zählen, und das bei Tempo 180.
vlG bab
P.S. aber Peter, ( egal wer sich jetzt auch angesprochen fühlt,) ihr hab jaa Recht.
Ich denk, versuch`s mal auf diesem ...ilegalen Weg, hihi
Drei Dinge braucht der Mann:
ein Auto
ein BMN
eine Tachoanzeige
mmmh,.. fehlt noch was :gap :gap :gap -
Für Tacho verwende GPSdash oder lese den VTG datensatz da siehst es ja auch oder verwendest halt ein anderes außer BMN da siehst es auch.
alle anderen komentare würden gelöscht (( ADMIN )))
Also wenn es ein Tool gäbe, das es erlaubt durch die Eingabe von Position (Long., Lat., Alt.) und Uhrzeit (z.B. UTC) die Akquistionszeit zu verkürzen, fände ich das toll! Es ist einfach total nervig aus dem Flughafen/Bahnhof-Parkhaus rauszukommen und dann entweder 15 Min. mit laufendem Motor rumzustehen oder blind durch die Gegend zu fahren. Insbesondere da die Umgebung mancher Flughäfen/Bahnhöfe echt uncool ist!
hallo henrich.wied,
du scheinst ja öfter mit Flieger und eigenem GPS-Empfänger unterwegs zu sein, deine Erfahrung würde mich mal interessieren.Ich hatte meinen CF-Empfänger (Pretec) erst zweimal im Flieger dabei, einmal war das Ziel ca. 1500 km, einmal ca. 4000 km vom Start entfernt.
Umso erstaunter war ich am Urlaubsort, dass der Fix beidesmal grad eine Minute, vielleicht 1,5 gedauert hat.Da war ich doch positiv überrascht, ich hatte eigentlich - auch aufgrund verschiedener Beiträge - mit wesentlich längeren Zeiten gerechnet (Almanach neu laden ? ).
Zumal die Pretec nicht besonders empfangsstark ist. -
Mein nächstes Ziel ist ca. 6000km entfernt. Ich berichte dann mal wie es geklappt hat. Bin selbst gespannt!
Also, hier mein Bericht: nach 7800 km bin ich in Miami, USA gelandet. Ich habe die Rikaline 6010 aufs Dach des Mietwagen gepackt und bin losgefahren. Nach exakt 10 Min. hatte ich eine brauchbare Ortung. Allerdings hatte ich mich zu dem Zeitpunkt auch schon das erste Mal verfahren. Klar kann man auch stehen bleiben und abwarten. Aber wenn man den Prozess durch einfache Initialisierung der GPS-Maus verkürzen könnte, wäre das schon schick (und technisch einfach sexy!).
Danke für dein Feedback.
Ich hatte damals den Fix ohne Empfängerbewegung erhalten, so gesehen nicht ganz vergleichbar.
Trotzdem hätte ich erwartet, dass Sirf schneller ist. -
ad navara
so einfach ist es dann auch nicht...
das ganze funktioniert nur wenn man korrekte angaben für zeit und ort zur initialisierung verwendet.
