Servus & :welcome: hier im Forum!
Sorry, I don't know what you mean, your links are blocked on my site (blocked_domain). :017: Perhaps you get your info in our Wiki or you've to repeat your question in other words. And some entries to your spezific HW / SW in your profile will help us, too.
I uploaded again.
Ah I see. I assume you did an incomplete setup, the settings (folder 18) is probably missing. Check our Wiki for further details.
Hello
I have this: Medion Gopal E3315
SD card must be something, when settings. What card do I need?
MN4-Speed.zipSie können eine Kopie Ihrer Karte? (E3315)
Füllen Sie jemanden wieder? -
Firstly, please write in english, the german translation isn't that good!
Without your cooperation we won't solve your problem properly. Did you check your setup? Which GoPal-Version do you use?
sorry
Gopal is not used. the device does not start. I need copy of the original card. card is just plain. no device menu. -
Once again, did you check whether your setup is correct? :017: Cause you're not posting your GoPal-Version you've to search yourself the appropriate page in the wiki -> http://www.gopal-navigator.de/…php?title=Portal:Software (every version is a bit different)
-> repeat the whole setup scenario
I do not know exactly what should be.
forum.pocketnavigation.de/cms/attachment/5678/
I need it? how to download? (E3315 M5)
what you need to download start? -
Ah ok, you have got GoPal v3, right? (then I've to move your part of this thread into the correct region*). In this version there is no extra folder #18 (it came later with v4.3)!
Check whether folder 0 & 1 have the correct content -> Wiki-Link. Now you've to start the setup with FF from CleanUp and HR.
And check whether your SD-Card will be recognized from the PNA.- - - - -automatisch zusammengefasst - - - - -
EDIT: * done
- occurred "Format Flash". erased any PNA. clear pna, and clear sd. I do not know where to download : pna menü. no menü, only "navigaton" and "settings" (pic1)
There's nothing to download, everything is on your DVD/CDs* in the several folders.*You do have an original DVD, do you?
there is no CD
Aha, why not? Didn't you get one with your PNA? Without a DVD you do have no legal GoPal license.
I bought second hand.Unfortunately, there is no disc. Would be sufficient only machine menus. Gopal program is not required. menu of the machine required
