deine vorgehenweise ist genau richtig. wenn das navi auch bei den blitzern warnt, ist es egal mit welchem der beiden tools du die LWD datei erzeugst ![]()
das speedlimit tool entfernt duplikate und sortiert die limits aufsteigend nach longitude und latitude. das navlwdb tool fügt die limits einfach in der reihenfolge zusammen, wie du ihm es per CSV vorgibst
BE794x Info und Tools
I still do not understand how to calculate Area width,Area height, if you could give an example I'd appreciate it.
1.0,, -1285360,3085570,1958114,1676616
= -1285360/72000 = -17.85222222 correct
= 3085570 * 9/1000000 = 27.77013 correct1958114??? and 1676616???
Longitude Right =9,300444444
Latitude Top= 42,859476(AreaX+width = LongitudeRight*72000
AreaY+height = LatitudeTop/9*1000000)Greetings.
suppose your area bounds are LongitudeLeft/Right and LatitudeBottom/Top
area width in meters = (LonRight-LonLeft)*72000
area height in meters = (LatTop-LatBottom)/9*1000000 -
Hello T|K and thanks for your patience, I have more doubts hazardareas.lwd file the default Limit mode appears Limit 13, the first warning limit 50 km/h 600 meters first notice and the second 200 meters, Limit mode changed and this is the result in a route of 50 km/h.
1 = 200/100, 4 = single 100, 5 = 150/100, 6 = 200/100, 7 = 250/100, 8 = 300/100, 9 = 350/100, 10 = 400/100, 11 = 400 / 100 12 = 600/100, 13 = 600/200, 14 = 600/100 and 15 = 600/100.
I could explain how to calculate the formula with an example, that with (value-1) * 100m not how it works.
Thank you.
The browser is a MyWay that own the Citroen and Peugeot.
It is a device manufactured by Harman Becker (German manufacturer of prestige), and of "MyWay" Citroen has made it, but the same device called RNEG elsewhere (radio navigation entrée de gamme), and is also Wip Nav known.
So MyWay, RNEG and WIP Nav is the same.
Greetings.
One more thing to make the file extract hazardareas.lwd limits.csv with its different sections, do you know if the sections are limited to lines as being very large in file browser does not work hazardareas.lwd.
Greetings and Thanks.
ok. but for the Becker Cascade series it works in the way I wrote...do you know if the sections are limited to lines as being very large in file browser does not work hazardareas.lwd.
no idea. you have to try it out by yourself -
Everything works fine example with a fixed camera and mobile camera.
https://rapidshare.com/files/1…n_Septiembre_07092012.rar
It only remains to see how to change the icons on the panel, these are the map data, as I can edit them???
EV043_v36a.gdb
EV043a_litdata.db
kN104EUx06.db
kN104EUx06T01.db
LABEL.DB
S_ZF1914_v1.DBGreetings.
This is the result after extracting with navfldb_tool
Can not be removed EV043_v36a.gdb
EV043a_litdata.db = *. LIT
kN104EUx06.db = *. ras, *. Xah, *. ort, *. plz, *. poi, *. b, *. v, *. xac
kN104EUx06T01.db = *. tlt
LABEL.DB = *. Txt
S_ZF1914_v1.DB = *. SM5You know how I can edit them.
Thank you.
Alles anzeigen
Das erste Problem wäre schon einmal gelöst - ich habe das Sample-Format der SP3-Container erfolgreich entschlüsselt.
So wie es aussieht sind in jeder der .raw-Dateien (nach Entpacken mit navlwdb_tool) zwei ADPCM-Streams interleaved gespeichert. Interleaved bedeutet hier, dass sich die Streams jedes Nibble (= 4 Bit) abwechseln.
Anbei ein von mir auf Basis der bereits geposteten Quellen geschriebener Decoder/Demuxer, der aus einer .raw-Datei zwei Dateien (eine pro Stream) im 8-Bit-PCM-Format generiert. Die dabei entstehenden Dateien lassen sich glasklar und vollkommen frei von Artefakten abspielen, bspw. mit aplay:
# ./devox_becker sample.raw stream1.pcm stream2.pcm
# aplay -r 16000 stream1.pcm
# aplay -r 16000 stream2.pcmWäre das also erledigt. Ich mache mich nun an die SP5-Container ran. Macht eigentlich noch jemand mit oder rede ich hier mit mir selbst
EDIT: das Tool kann testweise auf komplette Container angewendet werden:
# ./devox_becker D_MANN4.SP3 stream1.pcm stream2.pcm
# cat stream1.pcm stream2.pcm > stream.pcm
# dd if=stream.pcm of=stream_stripped.pcm bs=10000 skip=1
# aplay -r 16000 stream_stripped.pcm-> oder play_container.sh verwenden
.As I can use this tool
Greeting.
Ich habe interessantes Ergebnis:
die Daten für SpeedCams habe ich mit der Hilfe von SpeedLimit Toll erfolgreich in LWD Datei integriert (die LWD Datei habe ich von dem SpeedLimit CD für Becker bekommen) die Datei wieder zurück in TRACK01.raw ISO Image gepackt und in Becker installiert.
Jetzt habe ich folgenes Ergebnis:anstatt Warnunun / Pieptone sehe ich einfach die Geschwindigkeitsbegrenzung/ Zeichen auf dem Becker.
Was habe ich falsch gemacht ?:) -
for speech files *.SM5 you can use the navvoice_tool to modify the contents. that's all afaik...
du sprichst von blitzern auf der landstrasse?
das geschwindigkeitssymbol wird auch hier im navi-screen angezeigt. warum es nicht piept, kann ich so nicht sagen.
extrahiere doch mal die daten der neu erzeugten LWD. dann suche in der CSV mal den betreffenden blitzer und poste mal die komplette zeile hier.
passiert das bei jedem blitzer oder nur manchmal oder ...? -
With navvoice_tool *. SM5 = *. Raw and now I have to do
greeting
with navvoice_tool you can:- modify voice meta information (name, gender, language, ...)
- exchange samples (*.raw) e.g. with samples from Becker Voice CD's. the SM5/SP5 sample format ist still unknown...
