Für Deutschland. Näheres ist nachzulesen, insbesonders auch die Kompatibilitätsvoraussetzungen, bei Naviextras.
iGO 8.0.x ist aussen vor.
ZitatAlles anzeigenCompatibility requirements for this RDS-TMC service:
Please make sure your navigation device meets all of the below requirements before subscribing to this TMC service!
1. Your navigation device should have built-in RDS-TMC receiver OR built-in Bluetooth capability and a compatible external bluetooth TMC receiver.
2. Only devices with the following navigation software version numbers are compatible with this service: 8.3.x.71003 or later, 8.4.x.71009 or later (8.0.x is not compatible).
You can usually find the version number of your software in the Settings / About menu.
3. It is required that map of Deutschland (3. Quartal 2008 or later) is installed on your navigation device.
Should you have such older maps installed, please also buy the latest maps in order to use this TMC traffic service!
-> TMC pro iGO8
Und bitte keine Bemerkungen wie "TMC pro brauche ich nicht".... ;D
