I've buy Comand 2.0 for A-Klass.
what I need for install on my A-Klass W168 Reistayling (Year 2003)?
I know for connect (cable), but I don't Know for doppel Din.
Thank
Best Regards!
Thank
Best Regards!
The major expert for all of this (Holgi2002) has holidays
for 2 weeks....
regards
Wenni
There is no original part to get a 2DIN space in your car. You must cut out the frame yourself.
HI,
But not exist original part?
This navi wasn't sell in year 2003 into Mercedes?
THANK
Best Regards!
Of course, Comand 2.0 was sold originally in 2003, but not for the A-Class. There was no Comand available for the A-Class W168.
If you really want to use the Comand in your A-Class, you will have to build the fittings on your own.
By the way, which Comand 2.0 did you buy?
http://i64.photobucket.com/albums/h177/nellolo/comand2.jpg
At beging power Image Mercedes background is blue not black.
Thank
what is the Partnumber of this Comand?
What you need is an Comand from ML W163
with the Partnumber starts with A 163 XXXXXX
and a GPS Antenne.
Hallo Max,
wenn ich das richtig verstanden habe geht es hier um einen 2.0 Comand
in der A-Klasse 168.
Wenn dann passt da nur einer vom W 163 nicht vom W 164.
Der 164 hat doch schon Most.
Gruß Alex
Servus,
richtig, war ein Tipfehler.
Deshalb hatte ich gefragt, welches Comand er da überhaupt gekauft hat... ![]()
Comand is: A208 820 40 89
A-klass is reistayling W168 Year 2003
differt from A-Klass model 1997
http://img.subito.it/images/19/1963031334.jpg
Thank
I need of simultar of Can BUs?
THANK
BEST REGARDS!
depends on your comand...in case you have A163 Comand you dont need canbus simulator...otherwise you´ll need it.
Do you still need a 163 Comand 2.0? Im searching for a 210 Comand, because i need CAn Bus.
