ZitatAlles anzeigenOriginal von JEWUWA
Sorry, its me again
I installed MN7 and die cahnge the settings.xml to GPS Prot 1 and 9600 Baudrate - but still no GPS-Signal
Maybe it is because I closed in the beginnning of your Menu the GPS Splitter. Do you know how to react this and wich settings I do have to make there, If I start Spliiter now with Total Commander it is all greyed out.
Starting the DVICE new with the modded SD-Card I do have GPS but not after starting MN7.
If I insert the Original SD card without your menu I do not get GPS either,
If port splitter doesn't work the GPS port in MN7 must be "com 0" if port splitter is active must be "com 5"
If you don't want use Port splitter change this string
<GPSPort>1</GPSPort>
in
<GPSPort>0</GPSPort>
in version.xml
Naturally if you want use the original vdo software without my menu you simply use the button "delete registry" and turn Off-On
Hovewer the beta2 with several improvements is incoming I suggest to wait :gap
Zitat"Is there any chance to implement a SDHC-Driver like it is possible on PDA devices?"
Maybe yes but I need time... ![]()
A.
