ZitatAlles anzeigenOriginal von dmm1000
How to Know if MN6.5.1 is EXACTLY B297
First of all I apologise I have no German and can only speak English
I am in Ireland and have followd the instructions for the Becker 7934
I have copied all the files correctly and the Navigon software starts but - if i click on anything it says "The system couldn't find a map"
I have copied Europe_NT200708.map file to the SD Card so it must be finding the map because the Navigon Software starts ok - this means the script choose-mn.ns must be working OK
BUT - I am suspecting that i may not have the correct version of Build 297 (6.5.1)
Can anyone tell me is there any absolute 100% certain way to know if it IS 6.5.1 Build 297 because I know it is very important that is EXACTLY this
Is there any screens / files that will tell me EXACTLY if it IS Build 297 or not
if your MN 6.5.1 started correctly on TA 7934, then it is a MN 6.5.1 build 297. Other Versions would not start
if you ave used the choose-mn.ns script, just open it with a text editor and take a look on following text, whether the name of your MN6 Map matchs or not?
if not, just replace Map name and it will works.
var path="\\Storage Card";
var count=0;
var filename[];
var screen;function main()
var m[]={"*.map"};
find(path,m,gethashcount(m));if(count<=0){
playsound("\windows\infbeg.wav",ASYNC);
userchoice=msgbox("Keine MAP-Dateien gefunden!", "WARNUNG", 0);
break;
}for(i=0;i<count;i++){
if(filename[i]!="0"){
if((filename[i] == "DACH_NT2008.map")||(filename[i] == "WesternEurope_NT2008.map")||(filename[i] == "Europe_NT200708.map"))
CopyFile("\\My Flash Disk\\fonts\\arial.ttf","\\Windows\\Fonts\\arial.ttf");
CopyFile("\\My Flash Disk\\fonts\\arialk.ttf","\\Windows\\Fonts\\arialk.ttf");
CopyFile("\\My Flash Disk\\fonts\\arialbd.ttf","\\Windows\\Fonts\\arialbd.ttf");
Shell ("\Storage Card\MN6\MN6.exe", param = "", dir = "", style = 1);
break;
} else {
Shell ("\My Flash Disk\mnav\mnavdceOriginal.exe", param = "", dir = "", style = 1);
break;
}Cyber_Navi
Thank You Cyber Navi
Into the choose-mn script I have put in a message box which tells me if the correct map has been found on the storage card (SD)
When i click on navigation button it does execute the script and displays the message which saysIT HAS FOUND THE MAP Europe_NT200708.map
Now I did this to prove that it is finding the map on the card this means that the script can see the map on the Storage Card - agree ?
I have put this line into choose-mn
if((filename[i] == "Europe_NT200708.map") .......
userchoice=msgbox(filename[i], "IT HAS FOUND THE MAP", 0);
Also then Navigon starts with the splash screen and the rotating Navigon Icon
Then it comes to the main screen but all the menu items are grayed out - you can not click them - you can only click "Options" at the bottom.So then it goes to this screen and after a few seconds a popup message appears which says
"The system could not find a map"
When you click OK the Becker 7934 switches itself offI am puzzled what is causing this
Now the map is just one I have downloaded as a torrent - is there any sort of keys it requires ? - as far as i know from reading on the forum it does not require a keyI am at work now but i will send you some screenshots when i get home - but i am certain that it is finding the map on the SD card
i AM PUZZLED -
please check NaviLib.ini in Dir MN6.
Content:
[DB]
FileName = \Storage Card\[Properties]
ConfigFilesDir=\Storage Card\MN6\ConfigFiles\Advisor.SFSLast used database directory=\Storage Card\Europe_NT200708.map
bye
Rollo -
hy, bei mir läuft es aber ich hab da mal ne frage auf der sd karte im ordner MN6
ist ein POI ordner und darin ist ein ordner namens PoiWarner und darin die datei
PoiWarner.ovm heist das das da schon ein PoiWarner eigebaut ist wenn ja welcher?mfg oelftrut
Original von oelftrut
das ist Standard POIWarner von MN6.
Man tippt auf die Grundeinstellung und dann auf die Seite 4 von 4.
Vor Verkehrskontrollen waren, beantworten mit Ja.
Dann steht es auch zur Verfügung. -
also kann ich da auch einen anderen installieren kannst du mir da einen tip geben welchen ich nehmen sollte?
oder kann ich den standart auf aktuallisieren?mfg oelftrut
du kannst den Standard POI Warner auch aktualisieren.
(durch austauschen der *.ovm Datei)Oder den POI-Warner 3 installieren.
Thank You to RolloS60 and also to Cyber Navi
I am now slowly making progress and i hope this helps someone else in the future
Vielen Dank für Ihre Hilfe GuysZitatOriginal von RolloS60
Hi,please check NaviLib.ini in Dir MN6.
Content:
[DB]
bye
Rollo -
Hallo!
Hab seit kurzem auch das Becker 7934 und verzweifel daran MN6 zum laufen zu bekommen.
Ich habe folgende Dateien:
MN 6.5.1
Reality View (mit *.jct)
WesternEurope_NT2008Bekomme es nicht über My Flash Disk und auch nicht über die SD-Card hin.
Kann mir einer helfen?
Habe schon die ganzen Anleitungen durch aber bekomms enifach nicht hin!PS: Könn mich auch über ICQ anschreiben.
Mafi -
Es ist alles in diesem Thread lesen, wenn Sie von Anfang an - gut Glück
hi alle,
ich versuche gerade MN6 wieder drauf zu machen, und jetzt hab ich ein kleines problem, suche die 3 dateien (arial.ttf, arialk.ttf und arialbd.ttf), kann mir einer sagen wo ich dir her bekomme???Mfg KGB
danke an Cyber_Navi der mir eine anleitung gegeben hat, es funtzt wie schnitzel *lol*so jetzt hab ich kleines problem, sobald er das mn6 startet zeigt er mir einen fehler meldung an, nicht immer aber ab und zu
[Blockierte Grafik: http://img89.imageshack.us/img89/7486/7934et7.png]
was kann es sein, hab ich was falsch gemacht??? bitte um hilfe
Mfg KGB
Original von KGB80
Mfg KGB
Dialog_AddressBook.dat ist fehlerhaft.
