JVC KD-NX901 - Alles was ihr darübüer wisst!!!
  • A notice to chriZs pictures:
    What you see on these pictures is always the display in night mode. I day mode, the baggroud is enlighted and the signs on the display are black.
  • Yepp,
    that's true, you can set the display to auto, day or night-mode. I prefer night-mode as can be seen on the pictures.
    You also can switch the compass off or watch your current location (streetname, city) while not being navigated.
    I have no additional screen attached to the unit, so no video playback can be shown.
  • Thanks for showing the pictures! Indeed the colors match good, only the white buttons should have an other colour! Thanks for your support here everyone, i'm gonna buy this system and in a week or two, when my golf arrives it will be built-in! Then i will write down my experiences here!
  • Also another question, how is the tmc function working? IS it okay?
  • In german there is a strange translation of the beginning and the end of a traffic jam. but genereally, it is working good, it sends you off the motorway before the traffic jam and back on the motorway lateron.... and you can have a closer look to all trafficjams your radio received...
  • okay, thats nice, and is it reporting speed cam's also?
  • as far as i know, it is not reporting them. Is there a dataset in TMV reporting Speed-cams?
    Also the JVC does not know the speed-limit, as Becker for example does....
  • aha, well, i think it is sended via TMC because other systems (here in holland) like avic x1r can show speedcam's on the map. And what is stored in that 14GB of data on the HDD of the unit? Normal other units have only 4,7 gb(1 dvd) of space to use..
  • 1 DVD is not 4,7 Gig. Most Systems use dual-layer discs. And this is around 9 Gig.
    The JVC has 14 Gig for navigation data. But at the begining, there are only 7 Gig used. The other 7 are reserved for later updates.
  • And to tell you: there is no map - there are just those arrows with next and next turns (the next one, and the one afgterwards) - but even if you connect a screen to the device to view dvd, they will not show you a map....
    chris
  • well i've bought the unit, i will get my car this thursday so i'm very curious how it will be :)
  • Hallo! Habe mir das 901 geholt, und wollte auch mal meinen senf dazugeben (falls es jemanden interessiert!)
    Soundquali - ist meiner meinung nach super (hab allerdings auch 2 endstufen dranhängen)
    hatte vorher ein pioneer deh p3630mp mp3 radio, und meiner meinung ist der klang vom jvc ungefähr 10x besser!
    der radiotuner ist im gegensatz zum pioneer auch viel viel besser (beim pioneer kam bei radio hören nicht so richtig druck raus)
    bedienung ist total einfach und logisch
    einbau war auch total easy
    navigation ist auch ganz gut, aber die navi-stimmen (gibt nur 1x weiblich und 1xmännlich) hören sich total blech-mässig an (dafür auf jedenfall einen dicken minuspunkt)
    desweiteren habe ich heute einen 7" tft angeschlossen, und muss sagen die bildquali kann auch total überzeugen (wobei es auch noch div. einstellungen gibt z.b. zoom, 16:9 usw)
    wenn man dann eine mp3 cd einlegt, hat man auf dem tft die ordner und songnamen.
    also bis jetzt bin ich total begeistert (ausser von den robocop stimmen)
    falls jemand noch fragen hat, kann er sich gerne bei mir melden!
    2 Mal editiert, zuletzt von ()
  • Kannst Du mal ein Bild von den Anzeigen auf dem Monitor reinstellen? Das wär super.
    Also wenns geht jeweils ein Bild im HDD-Modus, SD-Karte und von CD/DVD.
    Ich nehm an, bei Navi (Pfeile) und bei Radio zeigt er auf dem Monitor einfach nichts an, sofern gerade keine DVD abgespielt wird!?
  • hi! kann ich morgen machen, wollte es gerade aber der blitzer wollte nicht so recht! (siehe bildanhang), navi zeigt er auf dem tft nicht an. (es gibt da so ein hintergrundbild mit jvc-logo!) im hdd-modues & sd karte muss ich mal schauen, habe es bis jetzt noch nicht ausprobiert! habe aber gerade nochmal eine dvd getestet mit viel bass ausprobiert und muss sagen es kommt richitg fett! der lautstärke regler (schieber?, wie auch immer) geht übrings von 0-50 - drückt man doll drauf geht er auch ganz schnell hoch oder runter! kann den übrings bis max 30 drehen und dann fliegt mir der kopf auseinander! PS: monitor wird morgen eingebaut (dann bekomme ich meine mk vom satller wieder)
