1. eine Datei namens "UniLi.txt" stammt IMO originär nicht von Medion :dontknow: Wo genau liegt sie auf der MFD und kannst Du so mal hier hochladen, gezippt?
2. warum klebst Du so an der 32GB-Karte? :017: Teste eine 8 oder 16GB, ob's da klappt.
Lohnt sich nicht zu zippen:
ZitatAlles anzeigen#32EK1111GPCA
b0b961bb8719fdbc62a95723f0605f81 *MapRegions\Austria.psf
49360c4e80e5a6eb6286b5dbc6db3d42 *MapRegions\Austria_TrafficPattern.psf
d2484749f0795e677c8100b6d2c33e82 *MapRegions\BelgiumLuxembourg.psf
1a51c289ba5e74321c605bcffaa6c723 *MapRegions\BelgiumLuxembourg_TrafficPattern.psf
1a15d89851a8722781a5c17df7363a7c *MapRegions\Denmark.psf
3fdd165f10fba168f1e0236b62043482 *MapRegions\Denmark_TrafficPattern.psf
81381ab01b4272dfa9fa96807a455852 *MapRegions\FranceCenter.psf
eb7e88e8ce7a40feea6b15722f7e6fa5 *MapRegions\FranceCenter_TrafficPattern.psf
f26b702b8031998c6088e3c677f72608 *MapRegions\FranceNorthEast.psf
4377f96c9fbe1d89c8bf50883df468ed *MapRegions\FranceNorthEast_TrafficPattern.psf
ea14e163ec3843054f395f782fa59518 *MapRegions\FranceNorthWest.psf
de84916ee451b05e2c11bbbdb2e07eee *MapRegions\FranceNorthWest_TrafficPattern.psf
e683b7f0d453af6f81e9cc0c05e1e1b9 *MapRegions\FranceSouthEast.psf
7079c16f2a96169c1679582135e5fe8b *MapRegions\FranceSouthEast_TrafficPattern.psf
b6df353028c40f1e3848c085f57b06ac *MapRegions\FranceSouthWest.psf
9a4f9271de0b2e8d45d0a87c4f4913e5 *MapRegions\FranceSouthWest_TrafficPattern.psf
8b34048f98c1fdcc90fe656392fc2ccc *MapRegions\GermanyEast.psf
f4daebe1aa3fb33fa2d09645985e8e76 *MapRegions\GermanyEast_TrafficPattern.psf
da1c2cbb75059f888f96634841c22b66 *MapRegions\GermanyNorth.psf
c3ae97afa2afa9d71d68d5a4c8952059 *MapRegions\GermanyNorth_TrafficPattern.psf
1497f39caf747becf220d1282fd1d68a *MapRegions\GermanySouth.psf
382723f50594f567d24b7201ba25c2bd *MapRegions\GermanySouth_TrafficPattern.psf
e1b12132dcd509bc753b64a6ebf70246 *MapRegions\GermanyWest.psf
c5a9dca8b8e460529206b39246685e19 *MapRegions\GermanyWest_TrafficPattern.psf
659ab08f089b217bc03a80ed9ec23a34 *MapRegions\Netherlands.psf
e0aa8a72bb37e273ec90509af69b6b6c *MapRegions\Netherlands_TrafficPattern.psf
e61e64aaf2389eb387ca1db6081a9f6b *MapRegions\Poland.psf
b884554c8038e933617d8f5935f125a3 *MapRegions\Slovakia.psf
10730c48dd9249c287cf460eb9c3665a *MapRegions\Slovenia.psf
5421d7c514172c2e0d18a1f45907345b *MapRegions\SwitzerlandLiechtenstein.psf
f98e73f017ccd759f4d2313fb4b262d5 *MapRegions\SwitzerlandLiechtenstein_TrafficPattern.psf
b64a5d5d791d80e8e100f25d79881b0d *MapRegions\WorldCartographicLayer.psf
65fca4942d0b53fbe9b787aa1e3a5a39 *MapRegions\ExitViews\EXV_0320x0240_H_C_D_0_0_0_0.cff
94950c35b354f6c80b1442e0b87041f0 *MapRegions\ExitViews\EXV_0320x0240_H_C_D_L_0_0_0.cff
b4a588a9de86b65a52648d51c64f0b8a *MapRegions\ExitViews\EXV_0320x0240_H_C_N_0_0_0_0.cff
cf42ea90f9869521cb05056bea17e658 *MapRegions\ExitViews\EXV_0320x0240_H_C_N_L_0_0_0.cff
4b2c40d41424de97751b556ceee6adea *MapRegions\ExitViews\EXV_0320x0240_H_F_D_0_0_0_0.cff
9d365aa0ff1652a635d018f91d35e82b *MapRegions\ExitViews\EXV_0320x0240_H_F_D_L_0_0_0.cff
f25f5146ee85444cda1d320124c8aeea *MapRegions\ExitViews\EXV_0320x0240_H_F_N_0_0_0_0.cff
bf3b4ea9c371314df669d99c19722e2f *MapRegions\ExitViews\EXV_0320x0240_H_F_N_L_0_0_0.cff
3a76593768f410b135c67bdeed4db9e3 *MapRegions\ExitViews\FORK_0320x0240_H_C_D_0_0_0_0.cff
c165385c6c63c4ef41e299e4a9bd41b7 *MapRegions\ExitViews\FORK_0320x0240_H_C_D_L_0_0_0.cff
8aa724fc6666bcd2c3910a6079280b28 *MapRegions\ExitViews\FORK_0320x0240_H_C_N_0_0_0_0.cff
306381b841cfa48c084bb7e747d89906 *MapRegions\ExitViews\FORK_0320x0240_H_C_N_L_0_0_0.cff
e52b762d0f817bc8bc9717748f661a43 *MapRegions\ExitViews\FORK_0320x0240_H_F_D_0_0_0_0.cff
500dbfa029322c89392f4f7a462c7836 *MapRegions\ExitViews\FORK_0320x0240_H_F_D_L_0_0_0.cff
0732481b7a49cf5bc66a7d36c86bd66e *MapRegions\ExitViews\FORK_0320x0240_H_F_N_0_0_0_0.cff
bfd94bccf699400d2e7f64cee2dd96c4 *MapRegions\ExitViews\FORK_0320x0240_H_F_N_L_0_0_0.cff
Das sieht eher nach der Bibliothek (Library) aus.
Und du bist sicher das du in der Bibliothek mehr Karten hast?
Danke Hawkw1nd! Und wo liegt sie?
Mhm, aber wieso haben bspw. die ExitViews alle eine einzelne ID? Und keiner der dort genannten IDs habe ich in meiner Bibliothek? Merkwürden! :denk_002: Aber diese Datei hat sicher nix damit zu tun, dass irgendwas nicht auf der SD erkannt wird. Auch, wenn sie einen ganz aktuellen Zeitstempel hat und aus irgendeinem Grund von einem GoPal-Task zusammengestellt wird.
Ich muß vielleicht noch ein bißchen ausholen:
Die Karten, die oben angegeben sind, waren vorinstalliert. Da im internen Speicher kein Platz mehr war, habe ich die Daten auf die SD kopiert und gleich die restlichen von der DVD dazu. Danach zeigte mir das Navi immer noch den Bestand von vorher an. Das heißt, von der SD lesen ist schon mal kein Problem.
Gestern habe ich dann über den GoPal Assisitent die Kartendaten synchronisiert - und zwar gleich mit der SD. Hat alles prima geklappt. Nun bekomme ich jedoch beim Einschalten den Fehler F3009: Das Format der installierten Kartendaten wird von der Software nicht unterstützt.
Nun verstehe ich gar nichts mehr.
Die UniLi.txt liegt übrigens direkt in der Root von My Flash Disk.
So soll's sein!
ZitatGestern habe ich dann über den GoPal Assisitent die Kartendaten synchronisiert - und zwar gleich mit der SD. Hat alles prima geklappt. Nun bekomme ich jedoch beim Einschalten den Fehler F3009: Das Format der installierten Kartendaten wird von der Software nicht unterstützt.
Naja, bei einem F3009 hat ja wohl nix "prima geklappt"! :icon_mrgreen: Wenn die Version der Maps kompatibel ist (-> Wiki), wurde danach ein SR/HR gemacht?
ZitatDie UniLi.txt liegt übrigens direkt in der Root von MyFlashDisc.
OK, vlt auch vom Pre-Setup. Dann scheinst Du wohl den PNA noch nie komplett neu aufgesetzt zu haben! :denk_002:
Ich meinte die Synchro ansich. Ja, ich habe danach einein HR gemacht.
Kompatibel sind sie lt. Wiki; es sind ja auch die original mitgelieferten.
Stimmt! Komplett neu aufgesetzt habe ich ihn noch nicht.
- - - - -automatisch zusammengefasst - - - - -
Bin gerade dabei, die Synchro nochmal anzustoßen. Gestern war ich, glaube ich, im Datenaustauschmodus (oder wie das heißt). Vielleicht liegt's ja daran.
Mach's doch manuell, über MSM. Dann wirst Du auch gefragt, ob überschrieben werden soll.
Wäre auch zu überlegen, dass mal zu machen.
So habe ich's ja vorher gemacht bzw. über einen Kartenleser. Mit dem Assistenten, dachte ich, ist dann die reguläre Variante weil er da ja auch noch andere Dateien schreibt wie z. B. die .apd-Dateien.
Jetzt habe ich allerdings immer noch den F3009 ...
... und werde wohl nicht drum rumkommen.
Soll ich den Ordner 28 mit
module.xml und Navirunner_Black_Pearl_xxxxxxxxx_xx_x.cab gleich im Installverzeichnis lassen?
Wie Du's machst, ist letztlich wurscht. Du kannst es auch über den Assi und einem CardReader machen.
Ja, kannst Du.
Du wirst es nicht glauben, aber nach dem Neuaufsetzen gibt's wieder den F3009!
Und jetzt ...
Ich habe mir mal die Installationsdaten angesehen und mit dem Backup verglichen. Aber da gibt es soviele Unterschiede, daß ich da überhaupt nicht mehr durchblicke.
Bringt es eigentlich was, wenn ich das Backup im MSM auf das Navi kopiere?
Was verstehst Du unter "Installationsdaten", etwa die *.cab's? :017:
ZitatBringt es eigentlich was, wenn ich das Backup im MSM auf das Navi kopiere?
Sonst wär's kein Backup. ![]()
Nein, ich bin mal alle Verzeichnisse durchgegangen und habe festgestellt, daß vor der letzten Installation manche Sachen drauf waren, die jetzt fehlen. Ich kenne die meisten Dateitypen nicht. CAB ist nicht dabei aber z. B. .vcb oder .teb.
Habe mich vielleicht etwas unklar ausgedrückt:
Das Backup habe ich erstellt indem ich einfach alle Dateien in diesem Massenspeichermodus vom Navi auf die Platte kopiert habe. Beim PC bringt das ja nicht viel wenn man auf diese Art und Weise Daten sichert weil eben durch einfaches Zurückschieben die ganzen internen Verweise zwischen den Programmen und dem BS nicht wiederherstellt. Sonst bräuchte man ja nicht diese ganzen Backupprogramme.
Ich weiß eben nicht, wie das bei so einem PNA funktioniert.
\My Flash Disk\Navigation\VehicleIcon\*.vcb oder \My Flash Disk\navigation\TTI\*\*.teb braucht's schon.
ZitatDas Backup habe ich erstellt indem ich einfach alle Dateien in diesem Massenspeichermodus vom Navi auf die Platte kopiert habe.
Mehr mach ich auch nicht.
ZitatBeim PC bringt das ja nicht viel wenn man auf diese Art und Weise Daten sichert weil eben durch einfaches Zurückschieben die ganzen internen Verweise zwischen den Programmen und dem BS nicht wiederherstellt. Sonst bräuchte man ja nicht diese ganzen Backupprogramme.
Backupprogramme machen noch wesentlich mehr, aber letztlich kopieren (und komprimieren) sie auch nur.
ZitatIch weiß eben nicht, wie das bei so einem PNA funktioniert.
Doch, aber nur im MSM, weil dann kein GoPal läuft.
