If there weren't any errors, it's ok.
And here is the exactly link -> http://www.wiki.gopal-navigato…le=GoPal_3.x_Installation
Okay. So I have clean upped everything, then installed the files on a sd card, put it in the device. It installed again. Then I put MapRegions on the sd card. But still nothing, again failure F3008.
Via the GoPal assistant on my computer, it says"I cannot find any installation software on the device.
What am I doing wrong?
OK, don't change your setup on the PNA any more. It seems to me that either your SD-Card is corrupt or you're using an incompatible CardReader though.
Workaround: try to transfer only your main map via the assi to the internal memory of the PNA.
Ok so I only installed 1 map under MapRegions, put it on another SD card and this works...but the GoPal assistant still says it cannot find navigation software?
Ah ok, if your Assi doesn't want to work you have to try another SD, formatted either FAT/FAT16 or FAT32.
Which kind of CardReader (type resp. name) are you using?
Why use another sd? The navigator works, the assi doesnt...
Cardreader is Hama, sd card was 4gb...now I used 1gb
Zitat von iggy2008Why use another sd? The navigator works, the assi doesnt...
Well, you still get F3008, right? That means, GoPal can't find any maps.
ZitatCardreader is Hama, sd card was 4gb...now I used 1gb
That sounds good!
Well actually, the Medion device doesnt give me F3008 anymore...it is calculating the route now. Dont know if it works tough, because Im at home and not moving ![]()
It is the GoPal assistant which says that it cant find navigation software in the device...
Ah sorry, you're right, I missed this in your posting above.
OK, did you update the Assi to the newest version V4.01.012?
No
How should I do that? And why?
How? From here: http://www.mediongopal.de
Why? Perhaps it solves your problem!
Ok so i installed the new version, but nothing. It still doesnt recognise maps in the gopal assistant. Moreover, when I am installing the programs on the MD95720, it gives me messages like : "file 240x320 was not copied successfully. Try again?"or file Berlitz.png was not copies successfully. Try again?"
What can I do?
You can check whether your setup contains all the required files and only them! Why do you need files for a resolution of 240x320 pixel? :smt017
Hello iggy2008
Please install your satnav with the original files, then copy only one map on the sd card. When it works with one map but dont work with all maps then your cardreader is not convenient or your sd card ist damaged.
Hi Navirunner,
I am feeling really stupid, but what do you mean with: "please install your satnav with the original files"? How should I do this? Should I delete anything on my SD card now?
Thanks again.
