MD 95720 and GoPal 3 install - F3008
  • Hello all,
    I am sorry to ask you the question in English but my German is not so good :)
    I have an older Medion device, MD 95720. Now for several days, I am trying to put GoPal 3.0 on it. Thanks to your forum, which was a big help already!
    But, now I have a problem and I cannot find a good solution for it. I am receiving this message: F3008...
    Just to check that I did everything alright (with flashing, and soft and hard resets). Can someone tell me, what is the whole process of installing GoPal? Starting with how to remove the present install...
    Or is there a more easy way to have the F3008 message go away?
    Thank you very much for your help!
  • Zitat von Navirunner
    You must install the maps of gopal 3.
    Thank you very much for your fast response. I have installed them though on my sd card. Its as if the system doesnt find them...
  • The maps must be in \MapRegions. But remember: maps and the GoPal-Version must match together!
  • Zitat von Ralf25
    Did both and still nothing...
    Maybe I have done something wrong with the flashing or installation? Maybe its an option to deinstall everything and try it again?
  • And by the way: I have put the maps on SD card...is that correct?
  • BTW: Location of the maps is written in the manual, SD -> \MapRegions or \My Flash Disk\MapRegions.
  • Correct, so I have that first option: \MapRegions but nothing...
  • Try to setup your PNA either with the GoPal-Assistant or use the way described in the GoPal-Wiki.
  • Zitat von Ralf25
    But shouldnt I first de-install everything? And if yes, how should I do that?
  • Yes and - again - check our GoPal-Wiki or try!
    BTW: what kind of PNA is behind the MD95720?
  • Okay so I found the cleanup info, thank you. When I'm at home, I will do the following:
    Clean-Up, remove all (or should I choose something else)
    Then set the device up through the GoPal assistant
    Do I need to do something else?
  • According to our overview -> http://www.wiki.gopal-navigato…Ger%C3%A4te%C3%BCbersicht your PNA is an CE Core 4.2 one!
    That means, you have to flash your PNA at first.
  • Yes I flashed it before...if I clean-up everything, do I need to flash again?
    Sorry for my many questions, but I dont understand much about it :) And I want to do it right...
