4.5a MP3 Player won't run on CE4.2
  • I installed only the mp3 player on Mio C710 (CE4.2 core). It takes well over 1 min to start and then it takes several seconds to respond to any click. And, it can't play any music. The device stops responding all together with the player probably taking all the CPU.
    Version 3 and 4.1 worked fine.
    Anything missing?
    ----- Translation by Google
    Ich habe nur den MP3-Player in Mio C710 (CE4.2 Kern). Es dauert weit über 1 min zu starten und dann dauert es einige Sekunden, um alle Klick. Und es kann nicht jede Musik spielen. Das Gerät reagiert nicht mehr, alle zusammen mit dem Spieler wahrscheinlich alle der CPU.
    Version 3 und 4,1 fein gearbeitet.
    Alles, was fehlt?
  • If your question is concerning a Mio-PNA why did you choose this board, not the special one for Mio, probably here? ?(
    Not sure, but perhaps your player does not like CE Core 4.2! Take the TCPMP (plays well on CE 4.2/5.0), more infos here, ClickMe
  • This is the only player I found that has big button for in-car use and works on CE 4.2. I've posted in other Mio forums but no one knows much about Medion MP3 Player there.
