Mortscript versus Becker 7934
  • [http://www.youtube.com/v/AdyAMFzMLRQ&rel=1"></param><param name="wmode" value="transparent"></param><embed src="http://www.youtube.com/v/AdyAMFzMLRQ&rel=1" type="application/x-shockwave-flash" wmode="transparent" width="425" height="355"></embed></object>
    there is a mortscript version to unlocked the becker 7934 into PDA version,
    who has it ???
    See movie on YOU TUBE
    its easyi, think
    i have tried the vesrion of the CARTREK and some program will run.
    Einmal editiert, zuletzt von sikkel ()
  • This looks really interesting.
    Do you can't contact the autor via YouTube-Message?
    I'll keep my eyes open, but I can't explain myself how does this work.
    I thought the WinCE is burned on ROM, so uneditable...
    We're running more and more programs on the 7934. I think we need bigger SD-cards ;)
    Regards,
    Jake
    Einmal editiert, zuletzt von JaKe2kOnE ()
  • I tried mortscript during my work at "PMB" (see footer). I remember that there are some files which must be copied to the device to get mortscript to run. These files are under copyright, so i decided to use ns which is similar.
    If you want to have a desktop on your 7934 as in the video, simply change the "Shell.exe" with something like "ShowTaskBar.exe". Then you have still no icons on your desktop. Create some, copy them to Flash Disk or Storage Card, create a little startscript which copy them back into the windows-desktop-folder and you have the same ... but on legal way. :D
    Ciaoi
    Alhifi
    (Sorry for my bad english)
  • What? I can't understand you. Can you describe once again?! ;D :gap
    On the video you can see he uses an different desktop-background and switch the power on.
    So either he uses a script, nor the 7934 is unlocked with a edited system-file, or both :)
    It can be the script only shows the desktop, and he just had modified some files to get full access to his windows?!
    Can someone try to get help from the becker support? :gap :gap
  • Hi :)
    I bought a 7934...and after a week of search on the net I can say :
    - You are the best boys for it! ;)
    My problem is about translate :-D) your work and all your (really cool) post\forum....I appreciate if someone could solve my doubts and questions on how to manage every PIMP!!!...but in english\italian!!! (we can create an english section) ...or an email direct contact :P ... APPRECIATE your works and time especially made by "Alhifi" always present in every post ...WOW!!! :D
    In my "private work" on it I was able to do such a work ;D :
    - same as Alhifi tell about MortScript! ;)
    But my problem is that I cannot run MortSript on windows start up ?( X( :( !!!!
    I must go to activate manually :( lunching after enter in My flash...
    Can U help me boys???? PLEASE!!!!!
    Let's open an english GLOBAL section!!!...and a preferred email line ;)
    I'm waiting for your HELP!!!!!
    P.s. Your PIMp is great but menu and programm will be in german :( not suitable for me....would like in ITALIAN....someone patiance to explain me how to have a PIMPED BECKER IN ITALIAN ????? PLEASE!!!
    Original von jobocu4
    I have no experience with Becker devices, but perhaps it is simular to my device: move (or copy) the mscr-file (Mortscript) to path Windows\Autostart
  • Tell us exactly what you want to do and we can help you!
    If you only want a windows-desktop, you must replace the file \My Flash Disk\Shell.exe, this is the original which shows the four buttons for navigation, music, picture and settings, with something else. Here you can use the software "ShowTaskbar.exe", which is in the PMB-Zipfile. Rename Shell.exe with whatever you want, then save "ShowTaskbar.exe" as "Shell.exe" in the My Flash Disk-folder. Then you have your desktop.
    If you want a little more like scripting or other programs to start during the boot-sequence, then look at "RunINI", which is also in the zip-file, but renamed into "ShellPMB.exe". You need "ShellPMB.exe", save it as "Shell.exe" to the My Flash Disk-folder, copy the File "RunINI.ini" in the same folder and edit it, it looks like below:
    [RUN]
    app1= "\My Flash Disk\Tools\ShowTaskBar.exe /hide"
    app2= "\My Flash Disk\Tools\ns.exe /mo '\My Flash Disk\Tools\nsscript\install.ns'",hide
    app3= "\My Flash Disk\ShellOriginal.exe"
    Here you can configure the programs which should be startet during the boot-sequence, in this example you see the second entry, which starts a ns-script ...
    During the boot-sequence the 7934 executes the "Shell.exe" (which is after the things above the renamed "RunINI.exe"), the programm starts everything which was found in the "RunINI.ini" in the same folder ...
    Hope it helps ...
    Ciaoi
    Alhifi
    Original von HSVMichi
    You can not save something permanently in the windows-folder on the 7934, only on "My Flash Disk" and, of course, "Storage Card". If something must be saved in the windows-folder, it should be done during bootup with a script and copy-commands ... but the only thing that is startet during bootup is the "Shell.exe" ... so this one must be replaced with something else ... look at PMB ... this one does nothing else, replacing the original shell.exe. But you cannot operate with the 7934 completely without the original "Shell.exe", because this one does some settings and the most important thing: it turned off the modlights!
    Ciaoi
    Alhifi
  • FIRST.....REALLY GREAT THANKS :D
    So many days of search on the web and hardly test of my own work...going mad :-D) ?( :evil: : drink :D
    to: HSVMichi
    As Alhifi says if I copy in the startup menu ...not work!!....nothing rests in "windows" when becker is turned off....so... isn't a real pocketPC?! :-O ?(
    to Alhifi :
    You ARE GREAT!!! :D
    I know well the "Shell.exe" is really important....and I've already tried the trik to rename it ;) all my script (I USE mortsript..... ns-script is better? same functions? is there a manual on how it works??? ) all done but my problem is the ability to do autorun operations at start up....
    SEEMS U've SOLVED MY PROBLEMS ;) I'll give it now a try!!...
    So here is what I'll do...
    ...Ok!!!!!!!!!! NOW IT RUN automatically :D ;) ALFIHI...GREAT again ;D
    Now...START with FINE TUNING :D
    Other questions:
    1)As u said MortScript has copyright...so when it's started appear a window :( not to beautiful see something like this....must press ok and close this window manually :evil: ....with other script no problem like this? can I start without this window??
    I know U used ns-script but I need a manul to managed it...and at this time,I've all my MortScript done :D
    2) is there any command that let me switch directly on desktop???...so I could run this exe in the RunIni and have my desktop at start up!!!
    3) is there something that let me desktop's shortcuts in the position I want...cause when I start up they go in the way they want ?( :(
    Thanks ....hope read u soon :]
  • ......I post my problems ?( and YOUR solution :D in post.... PIMP MY BECKER in ENGLISH .... THANKS TO ALL
    Other questions:
    No, as i remember it's not mortscript himself which has a copyright! To run mortscript on the 7934 you need some extra dlls in your windows folder and this ones are under copyright!
    At the moment i did not find the original nscriptm zip on the producer-homepage, so i put the manual here
    Read my postings! Replace the original shell ...
    Give "SystemInformation" a try, the software is included in PMB and a newer version downloadable at http://www.ultimatelaunch.de.
    Ciaoi
    Alhifi
  • Hi again ... :)
    Thanks for ns-script instructions...I'll give it a look so to try to change my script in this other program without copyright....
    Switch direclty on desktop I intend in such way.....
    Here is what I' ve done with My own PIMP :
    Clik On----------- start the original shell, but I've modified the button for the pictureViewer and changed (even in aspect image ;) ) ...when is press It activate (with script) all shortcuts on the desktop and show the taskbar....
    My problem is that the original Shell.exe still remain active and so the desktop (tha lie background the Shell) is not visible.....I must activate ITaskMng to STOP Shell.exe from running :(
    So if I could run a program (with SCRIPT) that in automatic STOP (REALLY) the Shell , than MY DESKTOP will be showed....or some command that bring the desktop in front of the shell.....but I'll preferred to STOP the Shell from running.
    Any Ideas???
    I'll give a look to "SystemInformation"....but is it in german? the site seems so...hope the program is in english
    Read U soon :D
  • just...another little question..... ?(
    When I install a program, obviously in "\my flash disk\..." via active sync all goes well but whne I switch OFF all system link are cancelled but I'v enoticed the program still work :)
    Seems Becker reset all window, perhaps even the registry and no way to find UNSTILL program in the controll pannel.....I've tried TCMPC (OK) , PocketXpdf (OK---but ONLY after copyng in the same directory "aygshell), JZPAIN (OK---same "aygshell")........
    Copying "packdll" in windows and all seems to work but if turn OFF...than On...all DLL are gone ?( X( ...WHY ?
    I ' ve also tried to INSTALL GAPI....same way....turn OFF...and all is gone :evil:
    Solution? ?(
    When I choose device in GAPI...I set Becker 7934 but all the choices say is not my device... ?( Why???
    I know I'm a bit ASKING ;) but as I said this is the only GREAT forum and GREAT PEOPLE ;) that can help me
    READ U SOON :D
  • There is no solution for this.
    The OS is burned on a ROM, so it can't get edited.
    You can use software with no install, resp. software which doesn't need system files.
    Or everytime you pull off the device, you install it again ;)
    Original von JaKe2kOnE
    You can always use software with installation-routines, no problem!
    Do a registry export BEFORE and AFTER the installation, compare them and save the differences in a text file. During the bootup set (with ns.exe) the registry-entries from the text file and, if it's required, copy the needed files into the right windows folders ... if the pathes to the files are stored in the registry, edit them to a place like My Flash Disk, so you do not have to copy it in the future.
    Ciaoi
    Alhifi
