* POI Warner an + aus mit 1nem Klick *
  • @ frabe
    deine pn ist voll :gap
    was genau möchtest du haben ?
    das mortscript oder den code aus der skn ?
    Einmal editiert, zuletzt von erste mühle ()
  • Hi em,
    ich bin halt ein kommunikativer Mensch. :D
    Ideal wäre das mortscript, den code aus der PFSkin und die Bilder (ich weiss ich bin faul :-D))
    Frank
  • Ist schon 4.1
    Bitmap
    703:PPSkin\100.png;
    SF_Map_info_icons
    // SkinElementModelCoder
    Class: SkinContainer;
    Coordinates: 340,3,160,20; // 379,3,100,20;
    //Background: 161,0,0,100,20,0,0,255,0,255;
    BGMode: transparent;
    TapMode: TapThrough;
    // FormModelCoder
    DynamicFormX: 0;
    DynamicFormY: 0;
    DynamicFormWidth: 50;
    DynamicFormHeight: 50;
    // SkinContainerModelCoder
    // SkinScrollbarOwnerModelCoder
    POIWButton
    Class: LauncherButton;
    Coordinates: 6,0,40,40;
    Enabled: 703,0,0,40,40,0,0,255,0,255;
    Pushed: 703,0,40,40,40,0,0,255,0,255;
    launch: "\My Flash Disk\Programme\mortscript\stopgopoiw.exe";
    Layer: ontop;
    tmc_button
    Class: NStateButton;
    Coordinates: 38,0,30,20; // 74,0,30,20;
    HAlign: center;
    Visibility#DP: 3407916; //FEATURE_RDS_TMC
    // NStateButtonModelCoder
    States: 10;
    StateChangeOnTap: disable;
    Enabled1: 9,0,0,1,1,20,25,255,0,255;
    Enabled2: 9,0,0,1,1,20,25,255,0,255;
    Enabled3: 9,0,0,1,1,20,25,255,0,255;
    Enabled4: 9,0,0,1,1,20,25,255,0,255;
    Enabled5: 9,0,0,1,1,20,25,255,0,255;
    Enabled6: 9,0,0,1,1,20,25,255,0,255;
    Enabled7: 9,0,0,1,1,20,25,255,0,255;
    Enabled8: 9,0,0,1,1,20,25,255,0,255;
    Enabled9: 9,0,0,1,1,20,25,255,0,255;
    Enabled10: 9,0,0,1,1,20,25,255,0,255;
    Pushed1: 9,0,0,1,1,20,25,255,0,255;
    Pushed2: 9,0,0,1,1,20,25,255,0,255;
    Pushed3: 9,0,0,1,1,20,25,255,0,255;
    Pushed4: 9,0,0,1,1,20,25,255,0,255;
    Pushed5: 9,0,0,1,1,20,25,255,0,255;
    Pushed6: 9,0,0,1,1,20,25,255,0,255;
    Pushed7: 9,0,0,1,1,20,25,255,0,255;
    Pushed8: 9,0,0,1,1,20,25,255,0,255;
    Pushed9: 9,0,0,1,1,20,25,255,0,255;
    Pushed10: 9,0,0,1,1,20,25,255,0,255;
    Icon1: 162,0,0,30,20,0,0,255,0,255;
    Icon2: 162,0,20,30,20,0,0,255,0,255;
    Icon3: 162,0,40,30,20,0,0,255,0,255;
    Icon4: 162,0,60,30,20,0,0,255,0,255;
    Icon5: 162,0,80,30,20,0,0,255,0,255;
    Icon6: 162,0,100,30,20,0,0,255,0,255;
    Icon7: 162,0,120,30,20,0,0,255,0,255;
    Icon8: 162,0,140,30,20,0,0,255,0,255;
    Icon9: 162,0,160,30,20,0,0,255,0,255;
    Icon10: 162,0,180,30,20,0,0,255,0,255;
    MinValue: -1;
    MaxValue: 100;
    CurrentValue#DP: 589825; //_OUT_TMC_STRENGTH
    FirstState#DP: 3801208; //MapView_TMCIcon_FirstState
    LastState#DP: 3801212; //MapView_TMCIcon_LastState
    // SkinButtonModelCoder
    PressedEvent: 2621504;
    battery_icon
    Class: NStateIcon;
    Coordinates: 74,0,30,20; // 40,0,30,20;
    Visibility#DP: 3801155; //BatteryIcon.visible
    // NStateIconModelCoder
    States: 8;
    MinValue: -1;
    MaxValue: 100;
    CurrentValue#DP: 1654787; //_OUT_GL_BATTERY_STATUS
    BitmapReference1: 8,0,0,30,20,0,0,255,0,255;
    BitmapReference2: 8,0,20,30,20,0,0,255,0,255;
    BitmapReference3: 8,0,40,30,20,0,0,255,0,255;
    BitmapReference4: 8,0,60,30,20,0,0,255,0,255;
    BitmapReference5: 8,0,80,30,20,0,0,255,0,255;
    BitmapReference6: 8,0,100,30,20,0,0,255,0,255;
    BitmapReference7: 8,0,120,30,20,0,0,255,0,255;
    BitmapReference8: 8,0,140,30,20,0,0,255,0,255;
    FirstState#DP: 3801153; //BatteryIcon.FirstState
    LastState#DP: 3801154; //BatteryIcon.LastState
    // SkinIconModelCoder
    gps_button
    Coordinates: 110,0,20,20; // 76,0,20,20;
    States: 14;
    Enabled11: 9,0,0,1,1,20,25,255,0,255;
    Enabled12: 9,0,0,1,1,20,25,255,0,255;
    Enabled13: 9,0,0,1,1,20,25,255,0,255;
    Enabled14: 9,0,0,1,1,20,25,255,0,255;
    Pushed11: 9,0,0,1,1,20,25,255,0,255;
    Pushed12: 9,0,0,1,1,20,25,255,0,255;
    Pushed13: 9,0,0,1,1,20,25,255,0,255;
    Pushed14: 9,0,0,1,1,20,25,255,0,255;
    Icon1: 163,0,0,19,20,0,0,255,0,255;
    Icon2: 163,0,0,19,20,0,0,255,0,255;
    Icon3: 163,0,0,19,20,0,0,255,0,255;
    Icon4: 163,0,0,19,20,0,0,255,0,255;
    Icon5: 163,0,20,19,20,0,0,255,0,255;
    Icon6: 163,0,20,19,20,0,0,255,0,255;
    Icon7: 163,0,40,19,20,0,0,255,0,255;
    Icon8: 163,0,40,19,20,0,0,255,0,255;
    Icon9: 163,0,40,19,20,0,0,255,0,255;
    Icon10: 163,0,60,19,20,0,0,255,0,255;
    Icon11: 163,0,60,19,20,0,0,255,0,255;
    Icon12: 163,0,80,19,20,0,0,255,0,255;
    Icon13: 163,0,80,19,20,0,0,255,0,255;
    Icon14: 163,0,80,19,20,0,0,255,0,255;
    MinValue: -1;
    MaxValue: 12;
    CurrentValue#DP: 65544; //_OUT_POS_SATELLITES
    PressedEvent: 3801097;
    brauch ich dir glaub ich nicht zu sagen, aber die Buchstaben vor der 100.png bei den Bildern müssen weg
  • Vielen Dank
    und meine PN-Box habe ich auch aufgeräumt- :D
    Frank
  • Hallo erste mühle,
    wie kann ich den Button installieren ?
    nw5110
  • Hallo nw5110,
    willkommen im Forum.
    Es wäre toll, wenn du neben deiner Hardware auch deinen Softwarestand hinterlegst !!
    Du legst dir einen Button als Bsp. in die MapView
    Codebeispiel für den Eintrag in die MapView :
    POIWButton
    Layer: ontop;
    - 703 = Beschreibt das kleine Bild -
    Diesen Eintrag in die Bitmaps
    703: PPSkin\100.png;
    Dann das Programm "Mortscript" installieren und die Dateien aus dem Download zwei drei Einträge höher in das Mortscriptverzeichnis kopieren.
    Das Bild 100.png in den PPSkin Ordner unter Navigation - Skin 480x272
    Deiner Frage nach zu beurteilen, solltest du dir folgende Links zunächst in Ruhe durchlesen :
    Wiki
    Einsteigerhilfe
    EDIT : Linksschreibung
    erstmal vielen Dank für die schnelle Antwort und Danke und Bewunderung für deine Arbeit ( und der aller anderen Skinner ).
    Ich bin schon froh es geschafft zu haben, einen anderen Skin zu installieren nach Schritt für Schritt Anleitung, aber mehr habe ich noch nicht drauf.
    Das habe ich auch nur geschafft, weil ich die Dateien nur auf,s Navi ziehen mußte, geht das mit dem Knopf nicht auch ?
    Meine Hardware PNA 470T MD96404, Software GoPal 4.1, Skin NaviToni V2.1 ( Sorry)
    nw5110
    leider ist das mit dem Knopf nicht so einfach. (für Unerfahrene :gap)
    Ich habe den Knopf in der Kopfzeile. (SF_Map_info_icons) Was und wie NaviToni in der Kopfzeile hat weiß ich nicht.
    [Blockierte Grafik: http://i34.tinypic.com/2z6vy1f.gif]
    Du solltest dich aber nicht danach richten, wo ich den habe, sondern wo du in hinhaben willst :)
    • Offizieller Beitrag
    Original von nw5110
    nw5110
    nein, das klappt so einfach nicht, da diese daten doch sehr skinabhängig integriert werden sollten.
    im übrigen wäre es nicht schlecht, deine daten nicht einfach nur so dran zu hängen sondern dein profil um die daten zu ergänzen! ;) wenn das geklappt hat, steht es im linken feld unter deinem namen. :)
    mfg rohoel.
    edit: mist, zu langsam. :-D)
  • :D
    Hallo Freunde ist dieses Thema noch aktuell ??
    Brauchte sowas für Teamskin 4.6
    Japy
    Original von Japy
    :D
    Japy
    geht
    ist auch bei mir im Skin 8)
  • EM.
    Das ist gut aber habe denn Team skinn der ist für mich am besten ab zu lesen
    Und wollte es so behalten.
    aber dein skinn ist echt erste Mühle äh erste Sahne meinte ich ;) ;)
    aber danke für deine schnelle Antwort !!!
    du bist schon ein meister vom Fach des skinnens .
    Japy
    Einmal editiert, zuletzt von Japy ()
    Original von erste mühle
    ich wollte nicht damit sagen, dass du meinen Skin draufspielen sollst :-D)
    :gap kannste aber :gap
    Das MortSkript in meinem neuen Skin ist aber noch ein wenig angepasst und funktioniert besser 8)
  • übrigens dein Skin habe ich drauf :gap :gap, habe denn Skin Tauscher drauf !!!
    Japy
    Original von Japy
    Japy
    freut mich :)
