Hallo all, Could somebody say me how I can unlock Windows CE (5.0) in my MEDION 465T (MD 96050)?
make a Softreset the Navi (the hole on the ground from navi, push with the stylus pen), when you see the second red grafic with "Go Pal" you push the "Flagbutton" this is the second Button on the right side. Now you see down a grey taskbar at ground. touch the taskbar and the go higher.
sry for my f**k english
hmm englisch sprechen find ich einfacher
Thanks, It's working, but how unlock this on constant?, because when I make soft reset everything it returns
Thanks, I will check it, It will suffice to full unlock? if I can after this operation instal TomTom or MioMap?
Original von mateo886
Sorry guy, unlock in this case means to have fully access to the desktop!
There might be a chance to get MioMap working on your PNA, some guys in this forum were successfull, check this fred here.
But the PNA-Version of TomTom runs on a linux OS, the WM-Version is a PDA one and between a PDA and a PNA there is a great difference (a lot of DLLs and Libraries), no chance so far!
ok, so How instal TomTom? Could Anybody write instruction for me? Where from I can download DLL's files?
Sorry, not ok so!
There is actually no chance, no one could achieve it so far, you would be the first! Try it and let us know!
EDIT: This forum doesn't support questions or any further infos an illegal software or files or how to get them. Probably all DLLs or you may need are under a Microsoft or anyone else licence agreement.
