Using a 910 as a speedometer ?
    how can I use the 910 to show me my actual speed ?
  • There is a manual that comes with the 910 ;)
    Change settings -> forward to status bar preferencse -> tick "speed"
    cu Peter
    do you mean the "Quick Start Guide" ? Or is there another handbook on the DVD which I have overlooked ? The PDF on the DVD seems exactly the same as the quick start guide and both are imo "bedürftig".
    Anyway I read the QSG several times and still cant find what you described to me. But thanks for the pointers!
    Nick
    Edited to add, I found the setting under Preferences as you described. But I still cant find any reference in the handbook other than something along the lines " there are many other options which you'd just better try and find out for yourself" ;)
    Einmal editiert, zuletzt von Northern Rocker ()
    Original von Northern Rocker
    The client got 100 points !
    Regards
    Fred
  • Sorry, never checked the manual - but it says on the DVD that there is a pdf-manual. So i thought that there should be some infos.
    If u play with ur GO and do the wrong settings or something goes wrong, there is always a button that returns the factory settings - also in the change settings menue.
    cu Peter
  • hi Fred,
    not that you misunderstand me, I know there is a PDF handbook on the DVD, but seriously, can you find any reference to the speedometer settings ?
  • Thanks buddy, I got it fixed now. You just have to look a bit (or ask here ;D )
