ZitatAlles anzeigenOriginal von Frank-W
* Asus A620 --> olijupp
* Asus A632N --> Lindwyrm
* Asus A636N --> Walter_K
* Asus A636 --> okosret
* Asus P525 --> psychoo
* Acer N10 (WM2003) --> Frank-W
* Acer N 30 mit BT-1000 --> Datastream
* Acer N50 --> MoJo1234
* bluemedia PDA 255 --> stoeberhai
* Dell Axim 3 (WM2003) --> piwa
* Dell Axim x50(WM2003SE)-->Kult5
* Dell Axim x50V (WM2003SE) --> UweR
* Dell Axim x51V --> bab
* FuSi Loox 410 --> Carsten_W
* FuSi Loox 420 --> thomas1904
* FuSi Loox N500 --> RaceBaggy
* FuSi Loox N520 --> ossinator
* FuSi Loox N560 (VGA) --> Howy
* FuSi Loox 720 --> spunky
* FuSi Loox T830 --> Kellermann
* HTC Trinity / P3600 --> Rodik
* iPAQ 1940 --> longtom76
* iPAQ 2100 --> RaceBaggy
* iPAQ hx2110 -->gallus001 (leider ohne Ton)
* iPAQ hx 2190b --> cyberalfa
* iPAQ 2210 --> bab
* iPAQ hx 2490 --> FastBerlin
* iPAQ hx 2750 --> 900SS-97
* iPAQ hx 2790 --> taucher0815
* iPAQ rx 3715 --> keyboarder2k
* iPAQ 3970 --> Gag Halfrunt
* HP 4150 --> bab
* iPAQ hx 4700 --> RalfCux
* iPAQ 5550 --> Rolli63
* iPAQ 5450 --> haha
* MD 95000 / PPC150 --> alexcom
* MD 96700 / PNA1500 --> Rage
* MD 96710 --> stefhu
* MD 40600 --> sn4km4n (GPS Problem -> Lösung: Maus umprogrammieren oder Com Splitter)
* MD 41600 --> Schulti76 (GPS Problem -> Lösung: Maus umprogrammieren oder Com Splitter)
* Mio168 WWER27 2003SE --> jhk_nl
* Mio A201 --> darkness_nightfall
* Mio A701 --> gringor
* Mio P350 --> Team PDA Max
* Mio P550 --> Team PDA Max
* MDA Compact --> Fuzzy-79
* MDA1 --> vorsti
* MDA II --> tom50354
* MDA Pro --> loew
* MDA Vario --> vorsti
* MDA Compact 3 (GPS integriert ohne TMC-Modul) --> technikfan
* XDA IIi --> Stangebelm
* XDA Neo --> Twingoli
* Toshiba e400 --> Markro
* Typhoone MyGuide 6500XL --> Stangebelm
* Vodafone Compact s (QTek s200) --> EngelOlli
* Vodafone Compact III (HTC TyTN) --> teebird
* Yakumo Delta 300 GPS --> wiwnet
* Yakumo Delta 400 --> Schulti76 (GPS Problem -> Lösung: Maus umprogrammieren oder Com Splitter)
* Yakumo Delta X --> Benni78
* Asus P525 --> psychoo* Acer N10 (WM2003) --> Frank-W
* Acer N50 --> MoJo1234* bluemedia PDA 255 --> stoeberhai
* Dell Axim x51V --> bab* FuSi Loox 410 --> Carsten_W
* FuSi Loox T830 --> Kellermann* HTC Trinity / P3600 --> Rodik
* iPAQ hx2110 -->gallus001 (mit Ton!)
* iPAQ 2210 --> bab
* HP 4150 --> bab
* iPAQ 5550 --> Rolli63* MD 95000 / PPC150 --> alexcom
* MD 41600 --> Schulti76 (GPS Problem -> Lösung: Maus umprogrammieren oder Com Splitter)* Mio168 WWER27 2003SE --> jhk_nl
* Mio P550 --> Team PDA Max* MDA Compact --> Fuzzy-79
* MDA1 --> vorsti
* MDA Pro --> loew
* XDA Neo --> Twingoli* Toshiba e400 --> Markro
* Vodafone Compact III (HTC TyTN) --> teebird* Yakumo Delta 300 GPS --> wiwnet
* Yakumo Delta X --> Benni78 -
ASUS A632
* iPAQ 2210 --> bab
* HP 4150 --> bab
* MDA1 --> vorsti
* MDA Pro --> loew
* Toshiba e800BT --> sunshine* Typhoone MyGuide 6500XL --> Stangebelm
* iPAQ 2210 --> bab
* HP 4150 --> bab
* IPAQ rx5935 --> Air-Cruiser (läuft nach Installation im ROM richtig flüssig)* MD 95000 / PPC150 --> alexcom
* MDA1 --> vorsti
* MDA Pro --> loew
Original von haha
@Guzschebauch
Bitte immer vom Letzten Beitrag eine Zitatantwort erstellen, ansonsten verschwinden die Einträge der nachfolgenden Beiträge !! -
* Asus A632 --> Gutzschebauch
* iPAQ 2210 --> bab
* HP 4150 --> bab
* MDA1 --> vorsti
* MDA Pro --> loew
* iPAQ 2210 --> bab
* HP 4150 --> bab
* MDA1 --> vorsti
* MDA Pro --> loew
* Yakumo Delta X --> Benni78mein Eintrag wurde gelöscht!
* Acer N35 --> ADVENA* bluemedia PDA 255 --> stoeberhai
* iPAQ 2210 --> bab
* HP 4150 --> bab
* MDA1 --> vorsti
* MDA Pro --> loew
* iPAQ 2210 --> bab
* HP 4150 --> bab
* MDA1 --> vorsti
* MDA Pro --> loew
* Toshiba e800BT --> sunshine* Typhoon MyGuide 6500XL --> Stangebelm
* Typhoon 7000XL --> dilase* Vodafone Compact s (QTek s200) --> EngelOlli
Bei mir läuft MN6 auf dem
Yakumo Delty X5BT.
2GB Sandisk oder 2 GB Hama
Tommy
* Dell Axim X5 (WM2003) --> otingokni
* iPAQ 2210 --> bab
* HP 4150 --> bab
* MDA1 --> vorsti
* MDA Pro --> loew
* Yakumo Delta X --> Benni78läuft auf meinm dell axim X5 soweit ohne probleme (gelegentl. leichtes nachhinken). im sd-slot sollte man die karte nur mit 1GB bestücken -> also kleineres kartenmaterial (2GB werden erkannt jedoch nur bis 1GB gelesen *grummel*) deshalb hab ich mir den jabo 17in1 cf adapter gekauft. den in cf-steckplatz und die 2GB SD rein.... voila auch die grosse europakarte funktioniert einwandfrei
Die liste wird langsam aber sicher zum Witz .
Weil um zu wiesen ob dein PDA , kompatibel ist oder nicht , musst du erst alle Seiten lesen .Und bei manchen Modellen , nicht mal so , weist du ob Ja oder Nein .
Die Idee war gut mit die verschiedenen Farben , aber mir scheint das manchen das immer noch nicht kapiert haben .
Ich kann nur sagen das Acer n50 ( Wie auch mit die vorigen Versionen ) nicht läuft , und Acer n35 ( Installation OK. ) aber der läuft so was von KAKE , das als nicht kompatibel eingestuft werden muss .
Ihr könnt natürlich so weiter machen .
Es ist nur meine Meinung !!!
* iPAQ 2210 --> bab
* HP 4150 --> bab
* MDA1 --> vorsti
* MDA Pro --> loew
* MDA Vario II --> lemmi42 (auch inzwischen von Navigon freigegeben!!)
