problem with navman 520 with TT5 soft
  • Hi!
    I ve just install tom tom 5 on my navman iCN520, fix is ok but I have a problem with maps.
    I ve copy the maps on SD but only Benelux map is work ok but what is it with rest of maps?? Navman did not detect it.
    Can sb write my a instruction where should I copy it or what should I do??
    Sb can help me?
    only English :)
    Cheers
    Arek
  • hi arek,
    which kind of maps you bought?
    Do you have registered the other maps yet?
    eGreetz
    Bodo
    this problem has two known reasons but only one solution
    Solution: you may try to format your SD-card after saving all containing data, then reinstall the maps
    Otherwise your software is from illegal sources, a well-known bug where we hesitate to aid you
    but i have the voices on this card and it's work ok
    I find the DVD with this map on it...
    Original von areknowik
    oh oh, you own a DVD? Sure its a legal version?
  • I m not sure that it's a legal version :/
    because sb sell me it and told me that it's a copy from legal version (witch that person destroy) :/
    i'm an idiot
    i'm an idiot
    Next step: Buy a legal version from TomTom, and then all your maps will function automatically :D
    Achim
