Hello everyone
My german is limited so I write in english
But please feel free to answer in german.
I have a 220CDI W203/2001 with a APS10 Radio installed.
I have purchased a APS30 on eBay and I have now realized from this forum that it can be several different models, and the seller doesn't write which model it is but he claims that it's an original mercedes-benz APS30.
I have also purchased a Becker silverstone 2662 CDchanger which I intend to connect to the APS30.
However now I see that this is not that simple and requires a special cable.
The seller has written this
Der 6 fach CD Wechsler passt an MercedesBenz Radios mit Lichtwellenleiter Wechslersteuerung D2B
Das Wechslerkabel wurde angepasst für MercedesBenz Audio 10 CC + CD / Audio 30 / APS 30 / Command etc.
I hope this means that the cable already has been modified, but my german is not good enough to see the difference?
So my question is:
Will the radio work in my W203?
Do I need to have the APS30 Enabled on a Mercedes workshop so I can see it on the dashcomputer?
Will I be missing any signals in the wirring loom, e.g. the Rûckfarth signal?
Do I need to have the CD changer enabled or modified in anyway?
Or is this all plug and pray (sorry play) ![]()
best regards
Henry
