Where may I get European maps for Medion MDPNA150?
    Where may I get the European maps, Baltic states inclusive for my Medion MDPNA150?
    Is it any source for this model?
    Thanks in advance for the help.
  • Hello vvv692,
    what kind of navigation software do you have on your MDPNA 150 and which cards where bundled with this software?
    As a matter of fact, there is neither alternative navigation software nor additional card material
    available for the MDPNA 150. Software and cards were always bundled with hardware.
    If you use a software like Medion Navigator 4.2, which is based on the Navigon Mobile navigator, then you could use the cards of the original Navigon Software and the cards of the Medion Navigator 4.2 for PDA(software with cards is offered often at ebay).
    But you can use only the cards not the software.
    If you do have the Medion Navigator 3.1D, which is based on Destinator3, there are no other
    cards known to me which you could use.
    For the Baltic states there is nothing available anyway.
    Regards
    Harald
    Original von vvv692
    do u have Destinator software installed on ur pna so u can get the all 3 cds <<<<hier>>>> .
    have nice eastern
  • Thank You for the link. I have yet registered. Hope I'll get the password in time. :)
