manual ???
  • Hoi,
    In the manualbook of MDPNA 150 you can find that jou can get a beter description of the MDPNA on your CD.
    But when i open my CD it is the same as the manualbook(not much).
    Does anybody know where i can get a good manual for the MDPNA 150.
    Or is there no clear discription????? :(
    Pieter
    Einmal editiert, zuletzt von kofroos ()
  • The Manuals are located in CD1 Folder Lang.
    CD1---->>Lang---->> (and then open the folder with your Language.)
  • Hewaan,
    Yes i know but that is the same as the manualbook???
    Isn't there a more clear manual.
    Pieter
    Original von kofroos
    Hewaan,
    Pieter
    I dont know where did u buy ur PNA. in Germany it has been deliverd with a really small manualbook which has only main informations about PNA. So the E-Manuals in Germany have really More Informations as in the manualbook. may be its same in ur country.
  • Hewaan,
    Is the manual in German somewhere on the www ??
    Then i can try to get the information from that.
    Thanks anyway for your replay!
    Pieter
  • Hoi,
    I found the manual !!!!! :D
    Thank for the reply
    Pieter
  • In the ActiveSync CD are also the manuals in almost european languages. i just saw that there are more usefull infos as the manuals from CD1.
