SanDisk Connect WLAN/WiFi SDIO Card und MdPna150?
  • Hello,
    I'm from Holland and my English writing is better than my German, so I write this in English. Nevertheless I hope you can help me with my question (you may answer in English and/or German).
    Question: Is it possible to use the SanDisk Connect WLAN/WiFi SDIO Card along with the Mdpna150? I read on this forum somewhere that the Mdpna150 is based upon the Mitac DigiWalker Mio 136. The Mitac Mio 136 has an SDIO connector (i read somewhere on the internet), so i would think the Mdpna150 also would have the SDIO connector, but I'm not sure.
    I installed the Avantgo software (the pocketpc version, available for free from www.avantgo.com) and this program runs great on the Mdpna150. You can browse the internet with this program (via ActiveSync). But Avantgo also supports Wifi connections and wouldn't it be great to use the Mdpna150 at so called Hotspots for internetbrowsing?
    Or just browse the internet at home if you have Wifi at home?
    I hope you people can help me. Thanks in advance!
  • Neem ff contact op per e-mail.
    Het is mij niet helemaal duidelijk.
    (Ich versteh das problem nicht ganz und kan besser in holländisch antworten)
