NEMERIX GPS GPS-BT77 hat jemand Erfahrung damit?
  • hallo,
    hab diese gps maus NEMERIX GPS GPS-BT77 über ebay ersteigert.
    war eigentlich recht günstig. jetzt möchte ich nachfragen ob jemand diese maus kennt.
    ja, normal frägt man vorher :gap
    über tips zum einstellen der maus mit TomTom 3 würde ich mich freuen.
    danke nadin1
    General
    Accuracy
    GPS Chip
    NEMERIX GPS Module
    Position
    Frequency
    L1, 1575.42MHz
    3meters CEP (50%), without SA (Horizontal) 7 meters (90%)
    C/A Code
    1.023MHz chip rate
    Velocity
    0.1 m/sec. without SA
    Channels
    16 CH all in view tracking
    Time
    ±100 ns synchronized to GPS time
    Antenna (Intemal)
    Built-in low noise
    Datum
    Extemal Antenna Port Active MMCX Antenna
    WGS-84 (or by demanded)
    Sensitivity
    Dynamic Conditions
    To 152Bm Tracking, Superior Urban Canyon Performance
    Altitude
    <18,000m
    Acquisition Rate
    Velocity
    <515m/sec
    Cold Start
    60 sec, average
    Acceleration
    <4g
    Warm Start
    38 sec, average
    Motional Jerk
    20 m/sec.
    Hot Start
    12 sec, average
    Interface
    Reacquisition
    1sec
    Communication Protocol
    Accuracy
    Communicate with host platform via
    Position
    5m CEP (50%), 9m (90%)
    Bluethooth (class 2) serial port profile
    Velocity
    0.1m/sec, without SA
    Bluethooth communication distance 10 M. TYP.
    Time
    ±100ns synchronized to GPS time
    GPS Protocol
    Power
    Default: NMEA-0183 (V3.01) GGA(1), GSA(3),
    GSV(3), RMC(1),VTG(1),Band rate 9600 bps,
    Data bit : 8, stop bit : 1(Default) *
    Built-in rechargeable 850mAh Li-ion battery and 5 V DC input
    Operation Current
    45mA (Typical)
    Operation Time
    18hrs, after fully charged, in continuous
    Device Size
    Charging time
    2.5hrs. (Typical)
    81 (L) X 44 (W) X 20 (H) mm
    Environmental
    3.2 (L) X 1.75 (W) X 0.79 (H) inch
    Operating Temperature
    - 20 to + 60
    Accessories
    Car charger (12V in, 5V output)
    Relative Humidity
    5% to 90% non-condensing
    AC adaptor (5V output, 500ma)
    :* (1):1sec output 1msg , (3): 3sec output 1msg
  • Hallo nadine1,
    guckst Du HIER
    Habe auch die BT77 günstig bekommen und sie funzt einwandfrei ohne Programmieren oder sonstige Klimmzüge.
    Konnte auch keinerlei Unterschiede zum "Original" XAiOX feststellen.
    Hope this helps.
    Greetz,
    overcast
