Johnny,
The TotalCommander install screen does not pop up on my Device
only on the PC.
After connection and turn on the Device I see THIS on my Device, the normal START screen >>>
[Blockierte Grafik: http://www.mijnalbum.nl/foto.php?m=fto&a=72&id=1539455&key=QNKAUSYA]
Then I click the tcmdwince.exe file ON MY PC and this screen I see ON MY PC the 'language chance option' and after that the DIR where the install will go to ON MY PC >>>
[Blockierte Grafik: http://www.mijnalbum.nl/foto.php?m=fto&a=72&id=1541503&key=WHDQYRQI]
[Blockierte Grafik: http://www.mijnalbum.nl/foto.php?m=fto&a=72&id=1539235&key=K6E4DUVN]
So far oke or not ?
FG Roel.
