How can I change the color of the progress bar ?
I mean the bar on the left side (original skin) which "grows" when you approach the next direction.
Oben your color-skin.ini in a text editor and change the value "mapbtnTextPressed" to your prefered color.
eg. "mapbtnTextPressed=00FF00" (lightning green)Hirni
the colorvalue are coded BlueGreenRed
and not RedGreenBlue.cu Luke
Okay,
Where can I find a table or something where all these buttons are defined ? I am new to this and would like to create some nice skins. -
ZitatAlles anzeigen
Original von Hirni
Hi,Oben your color-skin.ini in a text editor and change the value "mapbtnTextPressed" to your prefered color.
And where can I find this ? I cannot find color-skin.ini
open the ini-file of your skin
exemple:/programme/navig... /skins/your-skin/your-skin.ini
or
/prgramme/navigio../skins/color-skin/color-skin.inietc ...
dIdI
hi,
it's the file in the folder skin and the name called like
the skin you're using. eg.:
/path_to_MN/skin/LukeS/LukeS.ini , if you are using my skin.
otherwise the name is different, but I'm sure, you'll find
it.cu Luke
oh, to slow
Original von nomad_nl
Hi!
Normally the ini has the same name as the skin you try to modify e.g. standard.ini in case of the standard-skin.
This standard.ini you´ll find in the skins-folder called "standard".The colors of the Red-Skin can be changed in the red.ini which can be found in the "red" subfolder.
etc.CU
Super ! Danke !
Super ! Danke !bitte keine ursache ... für das sind doch wir hier im forum da *g*
dIdI
