Ich habe eine SanDisk WiFi "SDWSDB-000" gekauft. Ich habe versucht, eine Internetverbindung auf zu bauen. Leider ohne Erfolg! Mein Router ist ein DI-624+ von D-Link. Mein Internetanbieter ist freenet. Mit D-Link habe ich schon gesprochen. Deren Einstellungen, also "spezifische IP-Adresse" hat nichts gebracht! Beim einsetzen der Karte wird auch die Karte angezeigt. Beim aufrufen von Wireless Network Status wird unter Link Quality nichts angezeigt? Was muss ich tuen, oder welche Schritte sind nötig, um die Karte zum laufen zu bringen. MfG S.Krause
Ich habe auf eine Support-Anfrage bei denen mal folgende Antwort erhalten, vielleicht ist dabei ja was, was Dir hilft:
Use the drivers from our website for better result. I attached them to this email. After installing the drivers you will need to reset your PDA. Make sure that your PDA is an SDIO compatible. That is a requirement for SD wifi to function.
Here is the configuration that should be on your PDA. The bluetooth support should be disabled. Tap on the two arrows on the top of your PDA. go to settings-> click on connections and then the advanced tab. then Tap on the network card to connect to your access point (AP). AP browser will be grayed out, its normal as we didnt develop a utility for pocket pc 2003. Make sure you have the automatically connect to non-preferred network option checked. If there are no items listed in the wireless networks box you can add your AP by tapping on "Add new Setting" Type the network name for your wireless network. you can find in the configuration of your router. After you enter the name make sure connects to is set to "The Internet" and then tap on the authentication Tab. If you are not using the wep key . you can uncheck the box for wep. If you are using it on your router make sure to set it exactly the way it appears on your AP. When you finished making all those changes please tap on OK that appears uptop. IF your AP is on and within the range you should see connected next to it and the tower to the left of it will have a blue ring around the top. If you see a red X on the tower and it shows unavailable you should check the following: 1-IS the AP on
2- Is in range
3- are your settings correct.
Once you see the connected next to your AP you can tap ok twice and begin using your wireless access.Also please make sure to mention the technology used by your router. is it 802.11b or 802.11g If you have any further questions, please feel free to reply to this e-mail or contact our technical support department toll free at 866-SANDISK (866-726-3475). Our technical support team is open Monday through Friday, 7 am to 4 pm PST. Have a Great Day and thank you for choosing SanDisk!
Also, vielleicht hilft's!
William -
Hallo, leider ist es mit de Übersetzung für mich schlecht! Ob es auch in Deutsch geht? Noch eine Frage: Funktioniert die Karte auch mit dem Pc HP 2210?
MfG S.Krause -
Welchen Pocket PC nutzt Du den? Ich Frage, weil laut Kompatibilitätsliste von Sandisk nicht viele Geräte beinhaltet.
Hunzenplunz
Hallo, Sandisk gibit auf der Seite den Treiber vor!
www.sandisk.de/retail/drivers.asp; Producktnummer: SDWADB-000,
MfG S.Krause -
Habe seit heute die Sandisk Connect WiFi-Karte im Einsatz mit dem TCM MDPPC250 und es funktioniert. Also ist der PDA auch SDIO-fähig! Habe die Karte über ebay für 103,90 Euro bei Verkäufer "holbeh" erworben. WICHTIG: Erst aktuellen Treiber von www.sandisk.com runterladen. Diesen Eintrag habe ich mit dem PDA und der Sandisk WiFi gemacht. Grüsse Carsten
Ich habe leider OHNE Erfolg die drei HW-Generationen von der SD-WiFi SanDisk in Verbindung mit meinem e800-BT probiert. (HW-Version 1.0, 1.1, 2.0)
Dann habe ich mir die SD-WiFi von SOCKET gekauft und mit der funktionierte das WLAN auf Anhieb.
LG
RolandPS.: Mein Fazit: SanDisk baut nicht nur bei Memory-Card Mist. ;D :gap
Hallo, nun möchte ich nur noch wissen, wie es mit mein HP 2210 ist? Welche Karte ist für ihn gut? welche funktioniert richtig. Die von SanDisk war ja nichts! Vielleicht wohnt ja jemand in Berlin, der diese Karten verkauft und für meinen Pcket eine hat. Ich habe schon bei: Wir sind die guten und ich bin ja nicht blöd....., mein Glück versucht, nchts! Keine Ahnung! Ich benötige einen, der eine Karte in meinen PC schon mal zum laufen gebracht hat. Danke!
Hallo, wie Funktioniert das mit der SD WIFI Karte ???? Kann ich entweder meine SD Karte reinstecken in den PDA oder die SD WIFI KArte ????? Oder ist es möglich mehrere SD karten anzuschliessen ????
Ich habe den TCHIBO PDA MDPPC250.
VIELEN DANK FÜR EINE ANTWORT
____________________________________
www.bestell-guenstig.deMFG !!!!!
Es geht immer nur eine Karte pro Slot. Dein PPC hat nur einen Slot, also geht auch nur eine Karte zur Zeit.
-> Hin und her wechseln ist angesagt
habe bei mir (TCM und Sandisk Connect WiFi) die SSID nicht versteckne dürfen, dann gings. Wollte noch mein Passwort wegen 128bit Verschlüsselung und er hat sofort den Zugang gefunden.
Newwire
