Firmware Upgrade for PNA510
  • Hallo, sorry for my english, I have found on this forum a firmware upgrade (R11) for the PNA510, I have the PNA510MLR07 firmware, is this safe to install and what benefit I have to install?
    Thanks in advance!
  • Hello Riccardo64,
    welcome to the board.
    As long as I understand you and you understand me our english seems to be ok ;)
    (Kindly excuse my english! I try my best...)
    The FlashRom R11 in first is primarily intended to be used to make the older PNA500 / 510 compatible with GoPal 1.x and GoPal 2.x !
    (This R11 adds for example the CleanUp Menue for devices which have no CleanUp Menue at all.)
    (But not with any GoPal2 Version! Some Versions are special Versions for the "Big Display Devices" link the PNA470 / P4410.
    Please Note:
    The FlashRom R11 is only usable with PNA500/510 devices without additional internal storage.
    (There are some PNAs with 256MB internal storage and above - do not flash such an device with R11)
    P.S.: At the next opportunity I will translate the flashing instructions additional in english for our "non german" Users :)
  • thanks.
    I have the r07 firmware on my pna510, and i have installed the gopal 2.3 PE and it works fine (sometimes it freeze).
    I tries to install MS6 but not works, with the R11 there is the possibility to install?
  • Do you mean Mobile Navigator 6?
    Called MN|6 made by Navigon?
  • Zitat von GoPalFreak
    yes
  • hey, ich hab das trans...rom installiert und hab die installationsdateien von der cd auf die sd karte kopiert um das navi einzurichten... die installation wird aber nicht fertig, es startet immer wieder neu...
  • Hy, hbheiner
    Und du bist sicher, das du nach dieser Methode die Installdateien auf der SD hast?
  • Ich hab mal ein wenig gestöbert. Da hattest du am 27.Dezember letzten Jahres schon das gleiche Prob. -->Klick
    Immer noch nicht weiter gekommen, oder neue Probleme?
  • hey, danke...
    ...ja stimmt, ich hatte dieselben Probleme bereits...
    habe ja auch schon viel ausprobiert mit dem ding, es klappt aber alles nicht. sicher habe ich die installationsanleitung befolgt...
    die installationsroutine startet, läuft bis ende, dann startet das gerät neu und die installation startet auch wieder... immerwieder...
    was soll ich denn nur machen?
    mfg
  • Welche Softwareversion versuchst du zu installieren?
  • Tja, dass sieht jetzt ganz schlecht für dich aus.
    Das ist nicht die GoPal Version, die auf dem 500T mit dem Flashrom läuft.
    Lese aber selber mal diese Beiträge ab -->HIER.
  • dann brauche ich eine andere gopal software? 3 oder höher?... dann sollte es gehen?
  • sorry wegen dem doppelpost, war keine Absicht.
    also, ich hab die Beiträge dort überflogen und wie es aussieht, wird meine Software da nicht laufen. Werde mir eine neue GoPal Software besorgen und dann nochmal versuchen...
    danke
