Medion MDPNA 470T MD96080 FlashROM Upgrade. Checksum Error.
- GoPal E4110, P4210, P4410
- AVL
Zitat von AVL
And.... before my experiment with WINCE updait, my GPS navigator work wery-wery bad. In my apinion, my flash-chip is broken, bekoise funktion "Test memory" does not work correct.
OK, AVL, if you are sure, that you did everything, we advised you to do, and it didn't work so far, I'm afraid you're right and you have to contact the service. -
Hmm maybe sth. goes wrong with your file?
While unzipped maybe!The CKS seams to be a checksum CRC Check - so check the Checksum
Perhaps he didn't extract the files from the archive? :smt017 :))
EDIT: OK, was a joke! :)) He wrote in his 1. post: "Copy files: WINCEIMG.BIN und WINCEIMG.CKS to the card."
Zitat von Ralf25
Why not? :smt017 This tool is to check and format properly your MMC-/SD-Card.
Ralf25, your program SDFormatter V2.0 is very good and sucsessful format all cards, but my 470T is very bad
Can ewerybady test your PNA by "FLASH TEST"?
What you see on the screen duering the test?
And today i can test new cardrider. -
Hi AVL,
sorry, I'm afraid, if I do the test, I've to flash afterwards (if I won't exit the menu properly!).
Yes, try another cardreader, that's your last chance. :top
EDIT: but you can be sure that all the files/archives here are OK, otherwise all other users here must have had the same problems before
nase kala
Monika
Hat das Label GoPal E4110, P4210, P4410 hinzugefügt. -
Monika
Hat das Thema aus dem Forum GoPal 460 (E4110) / 465 (P4210) und 470 (P4410) nach MEDION mobile Navis (PNA) verschoben.
