New battery for Medion 96840 (E3212) ?
  • Hello,
    In Holland i just bought me a Medion 96840 (E3212). It has a 3 1/2 inch display, Samsung 400 MHz-processor and is based on Windows CE 5.0.
    I also want to use this GPS for hiking, for this I need a better battery then the one supplied with this Medion.
    I opened up the case and discovered that this device has the same battery as the one on MIO C230: S30 Rechargable Li-Ion Battery. 3.7V, 720mAh. BYD Company Limited.
    [Blockierte Grafik: http://www.oldeneibergen.com/images/akku_medion.jpg]
    What I would like to know is what the best battery would be to replace this S30 with? Offcourse i’d like this to be a battery with a very long lifetime.
    Kind regards.
  • Zitat von GoPalFreak
    Sorry I don't know which battery can be used to get it work longer.
    Maybe a Battery_pack as decribed in our GoPal-Wiki would be a solution for you...
    http://www.wiki.gopal-navigato…title=Benutzer:GoPalomino
    Hmmm ... I took a look at the website with this battery pack, not really what I had in mind. Any other suggestions ...
  • Monika
    Hat das Label GoPal Hardware Allgemein hinzugefügt.
