Transonic 3137 PROblem! Please help me if possible
  • I`ve downloaded from SD/MMC the wrong Winceimg but now I can`t enter the blue menu for download of new image.Please help me what can I do to enter to the initial menu bootloader menu. Pressing of both keys (power and PIO) does not result. My PNA has been died? Please help me.
  • Does it start anymore?
    Which FlashRom have you used?
  • Nothing appears on screen when switch on. Only blue indicator of bluetooth is flashing 1 time. I didn`t remember which image download into flash. old version was PNA 470 4410 R22
  • That is not really nice..
    The only thing you may try is to charge the device - maybe the power management is wrong after your flash-try.
  • The battery is fully charged. The green light indicates it. If you mean another thing, please say what can I do anywere? Is there any method of resetting of initial bootloading menu? How I can be informed about it?
  • Monika
    Hat das Label GoPal Hardware Allgemein hinzugefügt.
