Changes made from version 2.70 to 2.80:
-Added ability to sort waypoints alphabetically
-Improved GPS response at low speeds
-Improved ability to clear unit settings on power up: now only requires menu key and enter key to be held when powering the unit on
-Improved size of roads drawn on map in ‘automotive mode’ orientation
-Improved elevation data stored in track logs (etrex 30)
-Fixed issue that was causing some devices to display a ‘memory full’ message followed by bad device behavior
-Fixed issue with distance to destination data field
-Fixed occasional overlapping of data fields in the elevation application
-Fixed issue where waypoints and geocaches could be lost
