Becker Z203 Activesync connection possible or not?
  • Sorry for the english language but my level in german is very very low ....
    I use a gps Becker Z203 with PMB and @tomic skin V2 and I would like to add some other applications. For some of them you can easily find a ".cab" file and there is no problem to install it. But for some others (for instance "Memorymap") you can only find a Windows installer with an ".exe" or ".msi" file.
    In this last case the only way to be able to install it (if you have installed the needed dlls in order to improve the PND at a PPC level) is to use Activesync (Windows XP) or the equivalent for Vista and Seven.
    Does anybody know an easy way , and not to risky way to create an Activesync USB connection with the PC?
    Thanks by advance for any help ;)
