Neue Firmware 3.20
  • Change History
    -Changes made from version 3.00 to 3.20:
    -Correct items overlapping on the map.
    -Correct display of additional content in GPI data.
    -Make phone number in GPI content dialable.
    -All user favorites are now shown in the list (not just nearest 50).
    -Correct some connection issues in public transit navigation.
    -Correct issue that sometimes changed automotive routes to pedestrian routes after off-route recalculation.
    -Correct issue that sometimes caused automotive routes to change to point to point routes after power cycle.
    -Correct issues with Bluetooth audio and pairing.
    -Correct issue that could cause unit to shutdown with very large phonebook transfers.
    Correct issue that sometimes changed automotive routes to pedestrian routes after off-route recalculation. -
    ....würde manche hier zu Recht kritisierte sinnlose Route erklären.
    EDIT:
    Wie -->h i e r <--
    detailliert,
    betrifft das update ALLE 13XX und 14XX Geräte!
    Wünsche euch, das damit die Routing Probleme behoben sind
    Einmal editiert, zuletzt von Arnold1960 ()
