Change memory?
  • I don't know why, but I go for the underneath option:
    Eine andere Möglichkeit wäre bspw., Stefans Tool 'koord465' zu nutzen. Der Weg wäre sogar vorteilhafter für Dich, wenn Du das Tool schon auf Deinem PNA installiert hast bzw. es durch einen Skin/Menu installiert wurde. Ungetestet mal der von mir erweiterte Aufruf, so wie er in die MENU.XML in dem Bereich 480272 eingebaut werden müßte (vermutlich ist von Dir dann noch der Pfad zu koord465 anzupassen): <action path="\My Flash Disk\Tools\koord465.exe" param="window=0 copy=\Storage Card\Fonts|\Windows| SendKey=\Storage Card\MN6\mn6.exe"
    I already have this program on my Medion ( my flash disk \ programma )
    Like I understand I have to add something to the file MENU.XML, but the problem is that I can't find this ifle.
    I have placed the *.tff files my storage card ( storage card \ fonts )
    The reason that I would like to do this all is also because that I have installed "Navigon" on my Medion. I'm also using a mortscrip program which is installed in the directory: \\\WinCE Device\My Flash Disk\programme\
    Could you please give me a start ............
    Original von billy01
    You had a look at this: MN 6.5 auf Medion P4410 (Info-Box-Darstellung) ?
    Then write those 3 commands into a textfile, named RestoreFonts.mscr, and copy this into your MortScript-Path. Copy the MortScript-autorun.exe and rename it to RestoreFonts.exe and give your *.mscr a doubleclick!
    For testing purposes you have to delete or rename the *.ttf's.
  • I receive the message:
    "restoreFonts.mscr" There is no application associated with restorefonts.
    Run the application first, then open this file from within the application.
    What I did was:
    * created the file restorefonts.mscr with the text:
    Copy ( "\Storage Card\Fonts\arial.ttf", "\Windows\arial.ttf" )
    Copy ( "\Storage Card\Fonts\arialbd.ttf", "\Windows\arialk.ttf" )
    Copy ( "\Storage Card\Fonts\arialk.ttf", "\Windows\arialbd.ttf" )
    Copy ( "\Storage Card\Fonts\tahoma.ttf", "\Windows\arialbd.ttf" )
    Copy ( "\Storage Card\Fonts\tahomabd.ttf", "\Windows\arialbd.ttf" )
    run ("\My Flash Disk\programme\MortScript\RestoreFonts.exe" )
    And I placed this file in the directory: \\\WinCE Device\My Flash Disk\programme\MortScript\
    The I copied the file AutoRun.exe (from that directory) and named it: RestoreFonts.exe
    After double klicking on restorefonts.mscr I received the message: "restoreFonts.mscr" There is no application associated with restorefonts.
    What did I do wrong?
    Einmal editiert, zuletzt von billy01 ()
  • billy01,
    just curious: why the need to install additional fonts, and if those are necessary,
    why not install them in the default folder for fonts, namely \Windows\Fonts
    ( You might visit this site too.)
    Fonts residing in \Windows will not be recognized by OS.
  • At first, I've got my additional fonts for MN|6 in \windows and it works. But \Windows\Fonts is surely the appropriate folder. And \Windows\tahoma.ttf is IMO an original CE-Fonts.
    Perhaps the reason is, you didn't obey CaseSensitivity
  • You are right, it should be:
    copy ( "\Storage Card\Fonts\arial.ttf", "\Windows\fonts\arial.ttf" )
    Copy ( "\Storage Card\Fonts\arialbd.ttf", "\Windows\fonts\arialk.ttf" )
    Copy ( "\Storage Card\Fonts\arialk.ttf", "\Windows\fonts\arialbd.ttf" )
    Copy ( "\Storage Card\Fonts\tahoma.ttf", "\Windows\fonts\arialbd.ttf" )
    Copy ( "\Storage Card\Fonts\tahomabd.ttf", "\Windows\fonts\arialbd.ttf" )
    I would like to install these files in the windows\fonts map because I installed Navigon on my Medion to and that program needs the files.
    I can copy them on the Medion but every time after a hard reset the are deleted and with the above ????? it should work.
    Maybe you can help me?
  • You had read my first comment? It doesn't matter where the fonts are, it works anyway!
    Your problem now is MortScript -> CaseSensitivity (CamelCase)! And for what reason did you write the run command in your code?
    My last command was an answer to jwoegerbauer
    I will check and double check this.
    Good question ?( I will remove it.
    I assume that you mean the file which is installed in the directory \\\WinCE Device\My Flash Disk\programme\MortScript\autorun.exe ?
  • Maybe a stuppid question ........ but I have asked more :P
    Don't I have to install another program on the Medion from Mortscript?
  • I can't answer all your questions regarding MortScript. Please read that manual.
    If it allready runs on your PNA, it's ok. Otherwise you have to start MortScript.exe.
  • [Blockierte Grafik: http://i207.photobucket.com/albums/bb131/brucetheboss/16-10-200917-29-11.png]
    Copy ( "\Storage Card\Fonts\arial.ttf", "\Windows\fonts\arial.ttf" ) Copy ( "\Storage Card\Fonts\arialbd.ttf", "\Windows\fonts\arialk.ttf" ) Copy ( "\Storage Card\Fonts\arialk.ttf", "\Windows\fonts\arialbd.ttf" ) Copy ( "\Storage Card\Fonts\tahoma.ttf", "\Windows\fonts\arialbd.ttf" ) Copy ( "\Storage Card\Fonts\tahomabd.ttf", "\Windows\fonts\arialbd.ttf" )
  • Why does RestoreFonts.exe have a size about 8192 B and the other ones 7680?
  • When I look into other *.mscr files I see much more text in the files.
    Maybe that's the problem and do I miss some commando's
