NaviPOWM 0.2.3 und Vista
  • Hier noch ein Versuch mit der navipowm.txt
    Dieter
    // Documentation can be found on
    // http://navipowm.wiki.sourceforge.net/NaviPOWM
    // directories
    // Directories are taken as relative path to program
    // start path. To use absolute paths, one needs to
    // prepend the directory name with the path delimiter
    // for the used operating system: / for Linux
    // or \ for Windows. On Windows only directories on current
    // drive are supported. On Windows Mobile all drives are
    // subdirectories of \ so they can be accessed
    // Examples:
    // DirectoryMaps=Maps -> take maps from subdirectory Maps
    // DirectoryMaps=/home/OSM/Maps -> take maps from directory /home/OSM/Maps
    // DirectoryMaps=\OSM\Maps -> take maps from directory \OSM\Maps
    DirectoryIcons=Icons
    DirectoryMaps=Maps
    DirectorySave=Save
    // icons
    // config
    LogoTime = 3000
    FullScreen = off
    //FullScreen = on
    Northing = off
    //ShowMinimizeButton = off
    ShowMinimizeButton = on
    ShowMaxSpeed = on
    MaxSpeedSize = 51
    ShowCompass = on
    CompassSize = 50
    InfoBarBottomHeight = 20
    InfoBarTopHeight = 20
    InfoBarCommonWidth = 65
    InfoBarCommonHeight = 60
    //SnapToWay = on
    SnapToWay = off
    StartWithLastPosition = on
    WatchdogTimeout = 10
    GPSReceiverLag = 900
    // Mode
    // possible modes: car, bike, ped, cache, map
    // car -> car
    // bike -> bicycle
    // ped -> pedestrian
    // cache -> caching
    // map -> mapping purposes
    // SpeedThreshold* -> Speed detected as standstill for specific mode [m/s]
    Mode=car
    SpeedThresholdCar = 2
    SpeedThresholdBike = 1.5
    SpeedThresholdPedestrian = 1
    SpeedThresholdCaching = 1
    SpeedThresholdMapping = 1
    // zoom
    // AutoZoom = OFF
    // AutoZoom = ON;0;3;10;4;15;7;20;10;25;15
    //ShowZoomButtons = off
    ShowZoomButtons = on
    HystMaxOffsetRel = 10
    HystMaxOffsetAbs = 0.7
    // Scale
    ShowScale = on
    ScaleWidth = 100
    ScaleHeight = 5
    ScaleFontSize = 16
    // POIs
    // POIBackgroundType = Area / Glow
    ShowPOIs = on
    POIFontSize = 16
    POIDisplaySize = 20
    POIShowAll = off
    POIShowParking = on
    POIShowFuel = on
    POIShowTrafficSignals = on
    POIShowAmenities = on
    POIShowPublicTransport = on
    POIShowFoodDrink = on
    POIShowAccomodation = on
    POIShowChurches = on
    POIShowOther = on
    // Cities
    // CityBackgroundType = Area / Glow
    ShowCities = on
    CitySmallFontSize = 16
    CityMediumFontSize = 18
    CityLargeFontSize = 20
    // TrackLog
    //ShowTrackLog = off
    ShowTrackLog = on
    TrackLogSize = 3600
    TrackLogMinDist = 10
    // OSM validation
    OSMValiName = off
    OSMValiRef = off
    OSMValiMaxSpeed = off
    // Debug informations
    DBGDrawTimes = off
    DBGDrawMapSectionBorders = off
    DBGDrawPositions = off
    DebugFontSize= 16
    // serial port for GPS input
    // Here some examples:
    //SerialPort = COM1;38400;8;N;1 <- Windows
    // SerialPort = COM5:;9600;8;N;1 <- Windows Mobile. ":" needed
    // SerialPort = /dev/ttyS1;4800;8;N;1 <- Linux
    // SerialPort = DEMO;2005042301.txt;1 <- DEMO mode, timeout in seconds
    // SerialPort = DEMO;2005042301.txt;500ms <- DEMO mode, timeout in milliseconds
    //SerialPort = DEMO;demo01.txt;1
    SerialPort = COM6;34800;8;N;1 <- Windows
    Einmal editiert, zuletzt von meppen7 ()
    sieht eigentlich alles Korrekt aus. Weiss jetzt leider auf die Schnelle auch keine Loesung...
    Gruesse,
    Julian
    du solltest die Letzte Zeile von navipowm.txt:
    In
    ändern.
    Sonst ist mir nichts weiter aufgefallen.
    Gruß Ingo
    Original von meppen7
    Müsste die Datei nicht navipowm.ini heißen?
    Viele Grüße
    nein navipowm.txt ist schon richtig, dadurch kannst du die Datei auch auf einem PDA ändern denn bei einer TXT Datei wird einfach der normale Editor aufgerufen.
    Gruß Ingo
