backup problem update 8110 to 8310
  • I have downloaded te update 8110 to 8310
    But i wil make a backup and it will not work.
    the problem is Phoneme_EU.nfs
    Ho can i make a backup of de upgrade
    Gr,
    Marcel
    Original von Dewalt
    Gr,
    Marcel
    Simply put your SD-Card into a card reader (not into the 8110 device!), and Copy the contents of the card into any path on your harddisk.
    I suppose, as the freshly installed (and not yet played into the 8110) upgrade contains a number of "atypical" files (a number of PDFs, the files for the pictureviewer, the phonelink and the mp3player) Fresh won't accept a "regular" backup.
    (just supposing)
    Michael.
  • I can backup everiting of the sd card but not Phoneme_EU.nfs (233 MB)
    Then i get an error
    Marcel
  • 233MB is a large file - is it a time-out error-message (then try to ignore it)
    otherwise the file itself may be corrupt and you need a repetition of the upgrading.
    Michael
