I've try of install Comand 2.5 navigator into my car W203 year 16.08.2004,
but On screen, I have message: "Navigation cannot be activated".
What is?
Thank
Best regards!
What is?
Thank
Best regards!
comand 2.5 in c-class w203 (2004) ???
whats the part-number of the comand HU ?
btw:
what are you doing all the time?
1) comand in a-class w168
2) comand in e-class w211
3) comand in c-class w203
sorry for asking, but are you sure you know what u´re doin`??
Comand is w203 with 6,5" tft
Can you help me?
thank
Moin,Moin,
Navi aktivieren geht nur mit dem MB-Werkstatt-Laptop, das die Navidaten auf der Festplatte drauf sind.
Vielleicht kann das ja mal einer übersetzten ![]()
Translation: To activate navigation is possible only with MB-laptop because navigation-data are on the harddisk.
regards
Wenni
But this navigator not have hardisk, or I have traslate not correct.
Well, to be honest, it's nearly impossible to understand, what you have and what you did.
Exactly which Comand do you use? Comand APS NTG2 or Comand APS NTG 2.5? Give us the exact part number of the device.
If you use a Comand APS NTG2, there is no hard disk, correct. The NTG 2.5 does indeed have a harddisk.
