Performance schlecht nach Upgrade 7210 --> 7310
    Original von aquapulco
    <ShowFrameRate>1</ShowFrameRate>
    Thanks!
    Regarding TTS, I do think there is no solution for this. 7.4 is slower than 7.3, no matter whatever you change.
    MN7.4 doesn't update my screen until I'm 50 meters beyond the corner. Really disappointing, and the helpdesk was brutal... quite a difference with a few years ago.
    I hope they'll fix at least the performance in the near future... but being realistic.
    Maybe I should sell it after my trip and go back to MN7 PDA.
    Original von oVan
    Hm, thats not normal...
    Maybe someone else can given you a hint what to do.
    You can format your SD Card and copy everything again on your card, or redownload the update again. There is for sure something wrong with your installation.
    It happens mostly with Dutch TTS enabled, disabling that one solves almost all delays. Maybe someone can try this too?
    The card is the original 4Gb Class 4 micro SDHC from Navigon, delivered with the 7310ViaMichelin, so I think that one is definitely ok.
    just have a look to your coreconfig.ini. There is a section :
    [ThreadPriorities]
    Player=2
    SVOX Synth-Thread=2
    GpsReceiver=2
    BMapDraw=4
    TmcTuner=4
    TmcExternReceiver=4
    TmcCollisionChecker=4
    (maybe, your settings are different)
    When you decrease the SVOX priority (e.g. go to 3), your picture refresh rate should increase during TTS.
    On the other hand TTS may stutter with this setting.
    regards
  • Thanks! The settings were the same. I've changed the TTS priority to 3, and indeed it is a bit better, and without stuttering. But it's still not ideal, I'll try the combination with OldMapDrawer ;)
  • So, ich habe jetzt die Nase auch erst einmal voll. Das Stottern ist zwar weg und am Anfang scheint die Performance auch brauchbar, nach einiger Betriebszeit beginnt die Karte aber wieder massiv hinterherzuhängen, dann redet man nicht mehr von Frames pro Sekunde sondern von Sekunden pro Frame, teilweise aktualisiert auch nur das halbe Bild. Ganz schlimm wird es, wenn man ein paar mal in kurzen Abständen abbiegen muss, da kann man nie sicher sein, ob das Navi auch schon da ist, wo man selbst ist. (Alles mit Oldmapdrawer).
    Ich bleibe bei meiner Einschätzung: Irgendwo hat die 7.4er auf dem 7210 ein Speicherleck.
    Bin jetzt auch auf die 7.3er zurückgegangen, wow, wie schnell und unproblematisch das Gerät doch sein kann. Satfix - obwohl die 7.3 viele Wochen nicht aktiv war - innerhalb von 10-20 Sekunden, die 7.4er war bei mir nie schneller als 30 Sekunden, meist im Minutenbereich.
    Das einzige, was ich bei der 7.4er vermissen werde sind die grafisch angezeigten Alternativrouten bei TMC und bei der Routenwahl. Froh bin ich, dass ich die Angabe der Stadtteile los bin, was bringt mir eine Ansage "Richtung Sasel", wenn auf den echten Schildern "City" steht?
    Funktionieren die 7.4er Karten Q2 eigentlich mittlerweile auch mit der 7.3? Wie ist es mit dem Radarabo? Ich habe nämlich keine Lust, meinen Account auf 7.4 umzustellen - womöglich bekommt Navigon die Probleme ja doch noch irgendwann in den Griff.
    Original von ilam
    Ja das habe ich auch, das sich die Karte teilt, aber nur im DEV-Mode. Zumindest eine halbe Stunde ist die Navigation dann zu gebrauchen :-D). Das sich die Karte kurz in 2 Teile teilt, ist nur am Anfang. Im Normalmodus ist die Aktualisierung der Frames von Anfang an eine Katastrophe.
    Die Karten von 7.4 laufen nicht mit 7.3
  • Ich bin irgendwie tierisch genervt und stehe knapp vor einem Markenwechsel.
    - Die 7.4 hat genau die Funktionen, die ich an 7.3 vermisst habe, nämlich eine brauchbare Darstellung, was es bringt, wenn man den TMC-Umleitungen folgt. Dafür darf man das Gerät regelmäßig während der Fahrt neu booten und die Performance ist für "hakelige" Situationen teilweise wirklich zu mies.
    - Der 7.3er fehlen die neuen Funktionen, dafür ist sie schnell und stabil, hier bin ich aber meine Kartenupdates los, weil sie noch an der 7.3er kleben und eben mal hin- und herwechseln scheint ja nach allem, was man hier liest, nicht wirklich unkompliziert zu sein.
    Hinzu kommt ein äußerst dämlicher Kartenfehler auf meiner Standardroute in der Q2, der in Q1 nicht vorhanden ist und ich darauf hoffen muss, dass dieser in Q3 weg ist, aber ist ja auch egal, daran komme ich mit der 7.3 er ja auch vorerst nicht...
    Das Problem ist: Ich habe keine Hoffnung, dass es bei Navigon besser wird. Was wird jetzt angekündigt? DVB-T-Empfänger und Fotorealismus. Wie wäre es mal damit, dass das Beworbene überhaupt funktioniert, bevor man noch mehr performancelastige Funktionen ankündigt? Wie wäre es mal mit einer eigenen Kartenkorrekturfunktion oder eigenen POIs, die die Konkurrenz schon lange bietet?
    Original von ilam
    ... welche Routenoption (kurz, optimal, schnell, schön) nutzt Du ?
    Original von Bubber
    Meist optimal. Machmal auch kurz. Aber das dürfte ja nichts mit dem Problem zu tun haben, oder?
    Original von ilam
    eigentlich nicht. Ich frage nur, weil ich 2 mal "kurz"e Routen gefahren bin,
    und dabei / danach heftiges Nachhinken hatte. Das kann aber auch
    wirklich nur Zufall gewesen sein. Normalerweise nutze ich "optimal".
  • Die Performance in der Kartenansicht hat nichts mit der Routenoption zu tun. Was mir aufgefallen ist, einen kleinen Tick wird es besser, wenn man die Sprachsteuerung auf das geringste Maß runterschraubt. Dann erscheinen die Menu´s zumindest in einer halbwegs erträglichen Schnelligkeit, ohne sich den drehenden Navigonpfeil anzusehen.
  • Hallo!
    bin jetzt schon einige kilometer mit dem upgrade gefahren und es fallen mir immer mehr fehler auf so zb. auf der A61 Ludwigshafen Ri.Koblenz da geht es vor der Moseltal -Brücke der berg runter wenn ich da auf das Navi schaue ist bis kurz vor der Brücke überhaupt "keine" Brücke da.es sieht aus als würde man das Tal runter fahren wenn man dann auf der Brücke ist stockt das gerät etwas und es wird ne ganz normale straße dargestellt.Das gleich ist auch auf der A6 HN ri Nürnberg vor der Kochertal-Brücke da meinste echt du sitzt in der Achterbahn.
    einfach unglaublich
    Gruß timo
  • Naja, die Achterbahn bekommst Du mit Abschalten von Panoramaview weg. Wenn nur die optischen Spielereien Probleme bei der 7.4 machen würden, wäre ich im Leben nicht auf die 7.3 zurückgegangen.
    Original von dei71
    Ich habs noch nicht probiert, aber willst du damit sagen, wenn die Sprachsteuerung runter gestellt wird ist die Perfomance der Karte besser?
    Und was meinst du mit dem "drehenden Navigonpfeil"?
    Original von ilam
    Was denn noch? Sag mal, was dich da alles nervt!
    Einmal editiert, zuletzt von Megolk ()
