Ich habe heute im Netz was nettes gefunden - weiss nicht ob das hier schon bekannt ist:
ftp://krelectr:Fok94se@www.kr-…iles/StartUp%20screen.pdf
1. Connect USB that contains your customized startup screen ( for my test, I use a background with 640 x 480 pixels)
2. enter setup mode by:
- holding both SRC+EJECT and while holding it press the RESET button
- wait for the screen that displays:
- Kenwood Image
- OEM image
3. Select OEM Image
4. Select the file that you wanted to be the start-up screen, hit ENTER
5. You will be back to the screen described in (2)
6. Turn OFF unit by holding SRC
7. Turn ON unit by pressing SRC
