Change History
Changes made from version 3.30 to 3.40:
-Added Text To Speech support. After updating your nuvi 5xx, you must return to WebUpdater to install voices to enable Text to Speech.
-Improved G2 map compatibility by adding topmark display and the option to switch between IALA and NOAA icons, if supported by map.
-Improved highway avoidance behavior.
-Corrected issue when saving coordinates as a Favorite.
-Corrected issue where Optimally Reorder Points could cause final destination to be lost in some custom routes.
-Fixed some issues with handling certain Geocache files.
-Allow handling of maps larger than 2 gigabytes.
