@thegent
PN
Stefan
@thegent
PN
Stefan
Sorry ghostfish/Stefan...I got your pn thank you very much...Ill tell you if it works for me...
Thanks again
ZitatOriginal von ghostfish 1
@thegent
PN
Stefan
Ok Stefan...it did not work.....I loaded on the original software...
All I want is the Divx player and maybe a windows explorer...Is there a way i could load just that on to the GPS because the other stuff is in german and i cant understand that..
Thanks for all your help..
@thegent
PN
You need to download everything again and then unpack the first part, then the data via ActiveSync in the right places in Gps paste, you need only follow the prescribed paths,
You can also expand the menu Menüerweiterung GoPal 4 and follow the links to
Stefan
ZitatAlles anzeigenOriginal von ghostfish 1
@thegent
PN
Stefan
Thanks Stefan...
So i need to download and install the file from your first PN, then download and install the file from your second PN...
Ill try that and tell you how it goes....
One more thing Stefan.. do you know where i could find some POIs and some maps for my medion?
Thanks again Stefan..
http://www.navijoy.org/phpBB3/viewtopic.php?f=21&t=266&start=0&st=0&sk=t&sd=a
this is another forum for Gopal.
You need to log in and you can then Poi administration Mackula of 4.1 for download. But you must bear in mind that you are not all at once Poi in the card then there are problems with the software and the Gps no longer works. In the Skin of Navirunner is even Poi administration already installed.
New maps you can buy in the store Medion.
Stefan
Stefan
Stefan..you are a gentleman and a scholar...
Thank you for all your help
@thegent
Thank you
, I am glad that I could help you something ![]()
Stefan
Hallo zusammen
ich suche noch 3-5 Tester für die 6.5 ![]()
Die ersten 5 Meldungen hier bekommen post.
Gruß Navirunner
Wie? Noch keine Meldungen? Ich werde gerne testen. Allerdings bin ich kein Vielfahrer. Die wären bestimmt besser geeignet.
Gruß, Uwe
Misst ich habe mich per PN gemeldet, dann mach ich es hier auch noch mal, ein Vielfahrer bin ich auch nicht aber ich habe Zeit ohne ende. ![]()
Gruß Manni
würde auch testen.
Hallo Navirunner,
ich würde auch testen, vermute aber das eine Neuinstallation von Nöten ist, dazu habe ich aber nicht wirklich lust, sooo viel Zeit wie Manni123 habe ich dann doch nicht.
Habe derzeitig dein Skin 6.3 drauf!
@ Rookie69, Manni 123, AD1 und libero007
Ihr habt eine PN.
Gruß Navirunner
...danke
werde versuchen es so schnell wie möglich zu testen...
