hallo ,
verkaufe einen Bluethooth GPS Empfänger .. weil ich jetzt einen Becker 7928 habe und das Gerät nicht mehr brauche .
Hatt ich von Niederlande gekauft für 85 euro aber hab ich nur 1-2 mal benutzt das wars . es funktioniert einwandfrei aber leider ohne OVP
bei interessen einfach ne mail schicken
Lieferumgang :
Zigarette Ladegerät
[Blockierte Grafik: http://i30.tinypic.com/15sa0ib.jpg]
[Blockierte Grafik: http://i30.tinypic.com/2h5us1t.jpg]
Specs
1. Processed Channels: Track up to 44 satellites.
2. Update rate: 1 second.
3. Acquisition time Reacquisition, 0.1 sec., averaged
Hot start, 1 sec.,averaged Note 1
Warm start, 35 sec., averaged
Cold start, 40 sec., averaged
4. Accuracy Position, 5-10 m CEP Note 2
Time, 1 microsecond synchronized GPS time
5. Dynamic Conditions Altitude, 18,000 meters
(60,000 feet) max
Velocity, 515 meters / second (1000 knots) max
Acceleration, 4 G max
Jerk, 20 meters / second cubic, max
6. Datum: WGS-84
7. Sensitivity: -159dBm
Note 1: Outdoor-clear sky situation
2: Measured over 24 hours
II. Data logger Specifications
1. Up to 120K data records
2. Log data export for Google Earth and track maker
3. Programmable data log interval: time, distance, and velocity
4. Log data download by Bluetooth wireless connection, 10 meters distance.
III. Bluetooth Specification
1. Port type: compatible with Bluetooth 1.2 serial port
profile (SSP)
2. Transmitter power: class 2
3. Transmission range: up to 10 meters
4. Frequency range: 2402 MHZ ~ 2483.5 MHZ
5. Hopping channel: 79
6. Modulation: GFSK
7. Receiver sensitivity: -80dBm (typical)
IV. External Interface
1. Connection: Bluetooth 1.2 serial port profile (SSP)
2. Protocol: Default -- NMEA 0183 format with
command set (GPGGA, GPGSA, GPGSV, GPVTG, GPRMC )
3. Baud rate: 115200
V. Physical Dimension
Dimension: 77 (L) x 43 (W) x 17.6 (H) (mm)
Weight: 55 g (with battery)
VI. Environmental Characteristics
Operating temperature: -10 ℃ to +60 ℃
Storage temperature: -20 ℃ to +70 ℃
Battery charging temperature: 0℃ to +40 ℃
Humidity range: 5% ~ 95% no condensing
VII. Power Characteristics
Input voltage: 5V DC
Battery: Rechargeable Li-ion battery
Operating time: up to 20 hours at battery full charged condition
