Wenn ich am WE wieder zuhause bin werde ich mal Bilder machen----
Original von sasy
Wenn ich am WE wieder zuhause bin werde ich mal Bilder machen----Super, danke Dir!
dreamy1 -
Zwischenzeitlich hilft euch das auch ein wenig weiter....oder Ihr testet mit der angehängten Treiber Version indem ihr sie versucht einzubinden in euer WIN CE
SD Card Driver to SDHC Card Driver on WinCE 5.0 hardware platfrom
Hardware ------ SD Host Controller
HAL ------ SD Bus Driver
Client ------ SDIO Device/SDMemory
Component: SDCard
070405_KB933809 - This update installs SD Bus driver compliant with SD 2.0 Specification and an enhanced SD Memory Driver that supports High Capacity Cards of size > 4GB and up to 32 GB.
To enable SD Bus2 set IMGSDBUS2 = 1.
Note:
The new SD Bus and enhanced SD Memory Drivers for High Capacity Card Support might require OEMs to modify their SD Host Controller software if they were tightly coded to SD 1.1 Commands.
The file(s) with the new source code changes for this component can be found in the directory %_WINCEROOT%\:
public\common\cesysgen\makefile
public\common\ddk\inc\sdcard.h
public\common\ddk\inc\sdcardddk.h
public\common\oak\csp\arm\intel\pxa27x\sdhc\sdcontrol.c
public\common\oak\drivers\busenum\busdef\defbus.cpp
public\common\oak\drivers\sdcard\dirs
public\common\oak\drivers\sdcard\sdbus\makefile
public\common\oak\drivers\sdcard\sdbus\sdbus.cpp
public\common\oak\drivers\sdcard\sdbus\sdbus.hpp
public\common\oak\drivers\sdcard\sdbus\sdbusdef.h
public\common\oak\drivers\sdcard\sdbus\sdbusreq.cpp
public\common\oak\drivers\sdcard\sdbus\sdbusreq.hpp
public\common\oak\drivers\sdcard\sdbus\sdclient.cpp
public\common\oak\drivers\sdcard\sdbus\sddebug.cpp
public\common\oak\drivers\sdcard\sdbus\sddevice.cpp
public\common\oak\drivers\sdcard\sdbus\sddevice.hpp
public\common\oak\drivers\sdcard\sdbus\sddevinf.cpp
public\common\oak\drivers\sdcard\sdbus\sdiofeat.cpp
public\common\oak\drivers\sdcard\sdbus\sdslot.cpp
public\common\oak\drivers\sdcard\sdbus\sdslot.hpp
public\common\oak\drivers\sdcard\sdbus\sdworki.cpp
public\common\oak\drivers\sdcard\sdbus\sdworki.hpp
public\common\oak\drivers\sdcard\sdbus\sources
public\common\oak\drivers\sdcard\sdbusdriver\sdbusdriver.cpp
public\common\oak\drivers\sdcard\sdbusdriver\sdbusdriver.h
public\common\oak\drivers\sdcard\sdbusdriver\sdbusrequest.cpp
public\common\oak\drivers\sdcard\sdbusdriver\sdbusrequest.h
public\common\oak\drivers\sdcard\sdbusdriver\sdcardio.cpp
public\common\oak\drivers\sdcard\sdbusdriver\sdclient.cpp
public\common\oak\drivers\sdcard\sdbusdriver\sdenum.cpp
public\common\oak\drivers\sdcard\sdbusdriver\sdenum.h
public\common\oak\drivers\sdcard\sdbusdriver\sdhcenum.cpp
public\common\oak\drivers\sdcard\sdbusdriver\sdhceventhandlers.cpp
public\common\oak\drivers\sdcard\sdbusdriver\sdmain.cpp
public\common\oak\drivers\sdcard\sdcardlib\sdcardapistubs.cpp
public\common\oak\drivers\sdcard\sdcardlib\sddebug.cpp
public\common\oak\drivers\sdcard\sdclientdrivers\sdmemory\sdmemcardio.cpp
public\common\oak\drivers\sdcard\sdclientdrivers\sdmemory\sdmemdiskio.cpp
public\common\oak\drivers\sdcard\sdclientdrivers\sdmemory\sdmemmain.cpp
public\common\oak\drivers\sdcard\sdclientdrivers\sdmemory\sdmemory.h
public\common\oak\drivers\sdcard\sdhcdrivers\sdiostdhc\base\sdhc.cpp
public\common\oak\drivers\sdcard\sdhcdrivers\sdiostdhc\base\sdhc.h
public\common\oak\drivers\sdcard\sdhcdrivers\sdiostdhc\base\sdhcregs.h
public\common\oak\drivers\sdcard\sdhcdrivers\sdiostdhc\base\sdhcslot.cpp
public\common\oak\drivers\sdcard\sdhcdrivers\sdiostdhc\base\sdhcslot.h
public\common\oak\inc\defbus.h
public\common\oak\inc\sdhcd.h -
Original von Gerritje
Eine SD karte großer als 2 Gb kann grundsätzlich nur mit FAT32 formattiert werdenDas ist so nicht richtig
Auch eine 4 GB SD Karte kann mit >> FAT << formatiert werden
Edit Anfang
xxxxx ( Für unser PN4000/6000 muß sie mit FAT formatiert sein.) xxx
Karte funktionirt mit FAT und auch mit FAT32
Edit Ende
@ spat
Hallo sorry für die späte Rückmeldung
Wenn die Karte bei Dir nicht läuft setz ich sie in der Tabelle auf die nicht funktionierenden Karten.
In einem anderen Forum wurde mir diese Karte als funktionierend gemeldet.
mfg fiddi
@fiddi:
Das stimmt so nicht, dass die Karte zwangsläufig mit FAT formatiert werden muss. Ich habe meine Karten mit FAT32 formatiert und die laufen alle einwandfrei. Soweit ich mich erinnere, wird von einem Windows-OS auch nur die FAT32-Option beim formatieren angeboten, wenn eine 4GB-Karte benutzt wird.
Original von dreamy1
@fiddi:Das stimmt so nicht, dass die Karte zwangsläufig mit FAT formatiert werden muss. Ich habe meine Karten mit FAT32 formatiert und die laufen alle einwandfrei. Soweit ich mich erinnere, wird von einem Windows-OS auch nur die FAT32-Option beim formatieren angeboten, wenn eine 4GB-Karte benutzt wird.
Also in der Datenträgerverwaltung kann ich unter Windows auswählen
ob ich FAT , FAT32 oder NTFS formatieren möchte.Ich werde meine 4gb Karte jetzt auf fat32 umformatieren und testen ?
Test ausgeführt !!
Meine 4Gb Transcend Karte funktioniert auch mit FAT32 formatierung.
Danke für den Hinweis, man sollte eben alles selber probieren
mfg fiddi
@fiddi - besser wäre es zu wissen o. wissen, wo es nachlesbar ist: http://de.wikipedia.org/wiki/FAT16#FAT16
Mein bisheriges Schweigen zur SDHC-Problematik bedeutet im Moment, dass ich noch nicht weitergekommen bin. Und den zig Google-Verweisen auf russischsprachige Sites kann ich auf Grund meiner "hervorragenden" Sprachkenntnisse nicht folgen.
Hi !
Hab mir grade das 6000 gekauft und bin mir etwas unsicher wie man dateien auf das Gerät kopiert. Unten ist ein USBAnschluss aber kein Kabel. Kann ich wenn ich Videos auf die Karte kopieren möchte, dies auch über eine Kartenlesegerät machen? Im Handbuch steht was von syncronisieren ist das notwending? Brauch man dafür ein Kabel?
LG
Christian
@Dodiman - Welcome im Forum
Aber ich kann nicht nachvollziehen, warum es dir als einzigsten User verwehrt wurde, ein eigenes Thema zu eröffnen = hier geht es um Typ + Grösse verwendbarer SD-Karten und nix anderes.Kontakte einen Administrator und bitte ihn um entsprechende Löschung bzw. Korrektur.
Hallo, ich habe diese Karte OnMemory 4GB in FAT Formatiert und geht.
Original von Sonic07
Es ist unmöglich eine 4 Gb karte mit FAT (16) zu formatieren Nur FAT32 sollte gehen.
Bei Karten großer als 2 Gb gint es nicht einmal diese Wahl und bei Commandline Einträge folgt dann ein Fehlermeldung! -
morgen bekomme ich meine 4 GB SD Karte von Scandisk. Habe sie extra bestellt, da man ja kaum noch Karten bekommt die keine SDHC - Karten sind. Dann kann ich ja nur hoffen das mein PN6000 die Karte auch liest.
Werde weiter berichten.
Dirk
= schrott (verarbeitung)
läuft...aber....nach ständigen rein/raus ist mir die linke ecke der SD gesplittert und das VDO6000 erkennt sie nicht mehr an (sehr sehr selten wenn).
VDO6000 muss da irgendwo Kontakt haben und denkt ist keine drin.
Bei Karten großer als 2 Gb gint es nicht einmal diese Wahl und bei Commandline Einträge folgt dann ein Fehlermeldung!Schau dir doch bitte mal die Bilder weiter oben an !
Alles mit einer 4 GB Karte getestet unter win2000 , FAT, FAT32 und NTFS
mfg fiddi
Genau und wenn du mit einem 4 Gb Karte im Apparat FAT oder NTFS wählst kommt eine Fehlermeldung
Mit FAT16 ist nur eine Adressierung von 2 Gb möglich und NTFS formatierung von Speicherkarten ist überhaupt nicht möglich
