Szegediner Gulasch, ja der ist gut
So, ich habe heute mal VisaulGPSce laufen lassen, hier der der Log. Sats hat er keine angezeigt.
$PSRFTXTVersion GSW3.2.1PAT_3.1.00.12-SDK001P1.00c *3F
$PSRFTXTHTC GPS_ART_321000_GEN*20
$PSRFTXTTOW: 581171*32
$PSRFTXTWK: 1466*4C
$PSRFTXTPOS: 3841787 663833 5031066*33
$PSRFTXTCLK: 103040*37
$PSRFTXTCHNL: 12*5F
$PSRFTXTBaud rate: 57600 *51
$GPGGA,115338.021,,,,,0,00,,,M,0.0,M,,0000*58
$GPGSA,A,1,,,,,,,,,,,,,,,*1E
$GPRMC,115338.021,V,,,,,,,230208,,,N*48
$GPGGA,115339.003,,,,,0,00,,,M,0.0,M,,0000*59
$GPRMC,115339.003,V,,,,,,,230208,,,N*49
$GPGGA,115339.959,,,,,0,00,,,M,0.0,M,,0000*5F
$GPRMC,115339.959,V,,,,,,,230208,,,N*4F
$GPGGA,115340.959,,,,,0,00,,,M,0.0,M,,0000*51
$GPRMC,115340.959,V,,,,,,,230208,,,N*41
$GPGGA,115341.959,,,,,0,00,,,M,0.0,M,,0000*50
$GPGSV,3,1,11,11,54,281,,19,47,170,,14,42,081,,01,39,122,*7C
$GPGSV,3,2,11,22,26,058,,28,23,300,,20,19,230,,03,17,163,*73
$GPGSV,3,3,11,09,06,020,,17,03,319,,23,05,176,*4E
$GPRMC,115341.959,V,,,,,,,230208,,,N*40
$GPGGA,115342.959,,,,,0,00,,,M,0.0,M,,0000*53
$GPRMC,115342.959,V,,,,,,,230208,,,N*43
$GPGGA,115343.959,,,,,0,00,,,M,0.0,M,,0000*52
$GPRMC,115343.959,V,,,,,,,230208,,,N*42
$GPGGA,115344.959,,,,,0,00,,,M,0.0,M,,0000*55
$GPRMC,115344.959,V,,,,,,,230208,,,N*45
$GPGGA,115345.959,,,,,0,00,,,M,0.0,M,,0000*54
$GPRMC,115345.959,V,,,,,,,230208,,,N*44
$GPGGA,115346.959,,,,,0,00,,,M,0.0,M,,0000*57
$GPRMC,115346.959,V,,,,,,,230208,,,N*47
$GPGGA,115347.959,,,,,0,00,,,M,0.0,M,,0000*56
$GPRMC,115347.959,V,,,,,,,230208,,,N*46
$GPGGA,115348.959,,,,,0,00,,,M,0.0,M,,0000*59
$GPRMC,115348.959,V,,,,,,,230208,,,N*49
$GPGGA,115349.959,,,,,0,00,,,M,0.0,M,,0000*58
$GPRMC,115349.959,V,,,,,,,230208,,,N*48
$GPGGA,115350.959,,,,,0,00,,,M,0.0,M,,0000*50
$GPRMC,115350.959,V,,,,,,,230208,,,N*40
$GPGGA,115351.959,,,,,0,00,,,M,0.0,M,,0000*51
$GPRMC,115351.959,V,,,,,,,230208,,,N*41
$GPGGA,115352.959,,,,,0,00,,,M,0.0,M,,0000*52
$GPRMC,115352.959,V,,,,,,,230208,,,N*42
$GPGGA,115353.959,,,,,0,00,,,M,0.0,M,,0000*53
$GPRMC,115353.959,V,,,,,,,230208,,,N*43
$GPGGA,115354.959,,,,,0,00,,,M,0.0,M,,0000*54
$GPRMC,115354.959,V,,,,,,,230208,,,N*44
$GPGGA,115355.959,,,,,0,00,,,M,0.0,M,,0000*55
$GPRMC,115355.959,V,,,,,,,230208,,,N*45
$GPGGA,115356.959,,,,,0,00,,,M,0.0,M,,0000*56
$GPRMC,115356.959,V,,,,,,,230208,,,N*46
$GPGGA,115357.959,,,,,0,00,,,M,0.0,M,,0000*57
$GPRMC,115357.959,V,,,,,,,230208,,,N*47
$GPGGA,115358.959,,,,,0,00,,,M,0.0,M,,0000*58
$GPRMC,115358.959,V,,,,,,,230208,,,N*48
$GPGGA,115359.959,,,,,0,00,,,M,0.0,M,,0000*59
$GPRMC,115359.959,V,,,,,,,230208,,,N*49
$GPGGA,115400.959,,,,,0,00,,,M,0.0,M,,0000*52
$GPGSA,A,1,,,,,,,,,,,,,,,*1EWas sagt der? Ich kann das nicht interpretieren.
1017A
Huhu,
Das Log sagt mir.
- es ist 20 Sekunden, nicht 20 Minuten
- es ist ein Textauszug, keine Datei
- es zeigt keinerlei Signalpegelaber aus 20 Sekunden kann ich keine zuverlässige Antwort geben.
Also nochmal, diesmal 20 Minuten im Stand und im Freien, anschließend die Datei hier anhäbgen.
Wenn sich aber auch in 20 Minuten im reien keine Signalpegel zeigen, ist dein Empfänger oder deine Antenne oder das Kabel zur Antenne defekt.
Bussi
Rosi -
Hallo Rosi, Danke für die Info, das Ding lag eine Stunde im Garten, als ich kam, war die Gelbe LED aus. Es scheint wirklich so, als ob das ein Hardwaredefekt vorliegt. Ich bin jetzt einpaar Tage unterwegs und kann nicht testen, ich melde mich.
Servus
1017A
Huhu,
versuch mal, den internen Empfänger zurückzusetzen, z.B. mit Cruxview.
Vielleicht hilft das schon.
Bussi
Rosi -
Original von Rosemarie
Meines Wissens hat es bisher noch niemand geschafft, mit irgendeiner Software am GPS-Empfanger des Orbit irgendetwas zu programmieren. -
Original von gs.arch
Meines Wissens hat es bisher noch niemand geschafft, mit irgendeiner Software am GPS-Empfanger des Orbit irgendetwas zu programmieren.Noch nicht mal zurücksetzen ?
Könnte QuickGPS helfen ?
Noch nicht mal zurücksetzen ?.
Selbst ein solcher Fall ist mir nicht bekannt.ZitatKönnte QuickGPS helfen ?
Da ich immer mit QuickGPS arbeite, kann ich schlecht vergleichen. Schaden dürfte es aber auf keinen Fall.
Original von 1017A
QuickGPS ist aktuell.Gruß
1017A
Uiiii,
also, wenn 1 Stunde im Freien nicht reicht, Programmieren/Resetten nicht möglich und QuickGPS aktuell ist, sind die Möglichkeiten im Board imho erschöpft.
Hoffentlich hast Du noch Gewährleistung auf den Orbit, denn ich fürchte, der Service ruft.
Bussi
Rosi -
Also, noch mal getestet, Visualgps bringt nach 20 min noch immer "Fix not available", interpretiere ich richtig, dass kein Sat gefixt ist? Ich fürchte, Rosi, Du hast recht.
Servus
1017A
Ja, das interpretierst Du richtig
Falls Du mitgeloggt hast, her mit der Datei.
Vielleicht kann man noch etwas mehr sehen als im obigen Auszug.
Das wäre aber mehr aus Interesse, eine Lösung weiß ich auch dann nicht, wenn sich der Orbit so stur anstellt.
Bussi
Rosi -
Geloggt habe ich nicht, aber ich kann es ja wiederholen, als .txt?
Ja, als *.txt, das macht V-GPS automatisch und txt kann hier angehängt werden.
servus Rosi, passt des so....
