ZitatOriginal von evilp
VisualGPSce kann bei mir nicht laufen da TT in meinem AUtoradio installiert ist. Da habe ich keinen Internet zugang und kann auch nichts kopieren oder so.
Ich habe aber ein Menü in dem ich die GPS Daten sehen kann!? Nach was soll man den ausschau halten?!
Das sagst Du jetzt
Dann könnte das Springen auch an deinem Betriebssystem oder der Prozessorleistung liegen.
Worauf achtest Du im NMEA-Log:
Das sind 5 Sekunden Log für TomTom optimiert, nur das nötigste wird gesendet:
$GPRMC,140203.852,A,5134.1750,N,00718.1871,E,0.00,,240106,,,A*7B
$GPRMC,140204.852,A,5134.1750,N,00718.1871,E,0.00,,240106,,,A*7C
$GPRMC,140205.852,A,5134.1750,N,00718.1871,E,0.00,,240106,,,A*7D
$GPRMC,140206.852,A,5134.1750,N,00718.1871,E,0.00,,240106,,,A*7E
$GPRMC,140207.852,A,5134.1750,N,00718.1871,E,0.00,,240106,,,A*7F
$GPGSA,A,3,18,03,22,15,,,,,,,,,8.7,5.7,6.6*31
$GPGSV,2,1,08,03,68,156,34,22,59,089,32,18,29,050,32,15,26,072,33*75
$GPGSV,2,2,08,11,19,263,28,14,10,128,,08,07,310,,16,07,180,*7F
auch 5 Sekunden Standardsequenz, schon mehr Daten in der gleichen Zeit, die verarbeitet werden müssen (ohne ein mehr an Informationen für TomTom):
$GPRMC,124154.000,A,5008.4446,N,00821.0597,E,0.00,141.12,160606,,,A*66
$GPVTG,141.12,T,,M,0.00,N,0.0,K,A*0A
$GPGGA,124155.000,5008.4446,N,00821.0597,E,1,09,0.9,314.0,M,47.9,M,,0000*59
$GPRMC,124155.000,A,5008.4446,N,00821.0597,E,0.00,141.12,160606,,,A*67
$GPGGA,124156.000,5008.4446,N,00821.0597,E,1,09,0.9,314.0,M,47.9,M,,0000*5A
$GPRMC,124156.000,A,5008.4446,N,00821.0597,E,0.00,141.12,160606,,,A*64
$GPGGA,124157.000,5008.4446,N,00821.0596,E,1,09,0.9,314.0,M,47.9,M,,0000*5A
$GPRMC,124157.000,A,5008.4446,N,00821.0596,E,0.00,141.12,160606,,,A*64
$GPGGA,124158.000,5008.4446,N,00821.0596,E,1,09,0.9,314.0,M,47.9,M,,0000*55
$GPRMC,124158.000,A,5008.4446,N,00821.0596,E,0.00,141.12,160606,,,A*6B
$GPGGA,124159.000,5008.4447,N,00821.0596,E,1,09,0.9,314.0,M,47.9,M,,0000*55
$GPGSA,A,3,13,08,27,10,24,23,02,04,16,,,,1.5,0.9,1.2*34
$GPGSV,3,1,09,27,73,145,45,08,47,192,38,13,43,073,43,10,39,303,34*72
$GPGSV,3,2,09,02,38,242,33,04,24,205,38,23,10,080,34,16,07,025,34*7D
$GPGSV,3,3,09,24,06,183,32*4B
und das geht noch reichhaltiger...
