11g(54MBit) ist viel schneller als 11b(11MBit)
Verkaufe einwandfrei funktionierende SIDO Wireless Card nur 1x benutzt.
Habe meinen Organizer inzw. verkauft.
Lieferumfang:
1 x SD-54 WLAN Adapter
1 x Driver CD
1 x Case
1 x Quick Installation Guide
IEEE 802.11b/g compatible
Supports infrastructure and Ad Hoc Peer-to-Peer connectivity
Small internal antenna reduces the card size
Security supported WEP, WPA, WPA2
LED indicates link and activity status
SDIO interface compatible
Transmitting power: 11b 25.11mW, 11g 12.59mW
Support Pocket PC 2002/2003, Win CE 4.0, Windows Mobile 4.2⁄5.0
Connectors: SDIO
Data Rate: 11g:6,9,12,18, 24,36,48,54(OFDM)Mbps, 11b:1,2,5.5,11(DSSS/CCK)Mbps
Frequency Range: 2.412 ~2.484 GHz band
Physical characteristics: Dimensions: 40L x 24W x 2.1H mm Weight: 3.25g
Power consumption: Transmission: 250 mA (Max), Idle: 3 mA, Sleep: 1 mA
Approvals: FCC/CE
Operating Temperature: 0 to 40 °C
Storage Temperature: -20 to 70 °C
PDA, Pocket PC&;Mobile Computing device with an SDIO slot running SDIO Now!
Support Win CE 4.2, Windows Mobile 2003 & 2003 Second Edition.
[Blockierte Grafik: http://img258.imageshack.us/img258/4571/img2005esr1.th.jpg]
30,- EUR
