problems getting poi's visible in TT6
  • Ok, first, sorry for writing in english, my german is poorly in writing, but reading exelent.
    i got poiwarner 2.71 for my pda for some while, so that i rid of the 180 degrees detection in tomtom (speedcams *G*) (here in the netherlands it is still legal)
    after installing poiwarner on my device, and entering the reg code (legaly, what else) ,i did some setup things as in the manuel written.
    but now comes the the thing where i got stuck.
    below screenshot is from the english manuel.
    [Blockierte Grafik: http://home.wanadoo.nl/spatieman/tt/zoom.jpg]
    i SHOULD seen above screen, but i do not see it in poiwarner
    what i do, i do not see it.
    this, is what i see.
    [Blockierte Grafik: http://home.wanadoo.nl/spatieman/tt/Image4a.jpg]
    after reading the german manual, above screenshot is not in the manual.
    ok, in poiwarner i set poiwarner to show the poi when it is nearing the poi to show up in TT6, (in TT6 i deactived all poi's for performance isue)
    if i where right, poiwarner should make the poi visible when it is in range.
    it does not happen.
    customer support cant help me directly ,so i post in the forum my problem.
    perhaps any one else here knows this problem.
    (on TT5,previeus clean install) also didnt work)
    i can add all the poi's i want, set the detection time, set all the sound files, any thing, but no poi's come up in tomtom.
    help..
    Regards Tony.
    P.s
    answers my in german, as i sayd
    i can read it..
    2 Mal editiert, zuletzt von spatieman ()
    the Picture is from the POI Warner for MN6.
    The Feature does imho not exist in the POI Warner for TT6.
    The POI Warner for TT6 dosn't work with TT6.03, only with TT601.
    Gus
  • mhh, manual say's TT5/6 edition.
    oh, as you see, i edited the post.
    mhh, how do i check the TT6 version.
    i think i have 6.21 on my device.
  • yes.
    wrong german manual.
    in english it is not..
    any way, i hope that they will fix it soon.
    only a audio warning sucks, i want visual to.
    and visual i only get when i enable them in tomtom.
    deu the fact that i have over 300 poi's , what was the reason for buying poiwarner.
